Plex subtitles encoding on ubuntu 20
Server Version#: 1.21.1.3876
Player Version#: all
Hello,
I have a wrong subtitles encoding when I upload them. When I update my server installation I have this:
PlexMediaServer install: PlexMediaServer-1.21.1.3842-b0c7a97d9 - Installation starting.
PlexMediaServer install: Now installing based on:
PlexMediaServer install: Installation Type: Update
PlexMediaServer install: Process Control: systemd
PlexMediaServer install: Plex User: plex
PlexMediaServer install: Plex Group: plex
PlexMediaServer install: Video Group: video
PlexMediaServer install: Metadata Dir: /home/tomtom0013/sauvegarde/plexmediaserver/Library/Application Support
PlexMediaServer install: Temp Directory: /tmp (set in Preferences.xml)
PlexMediaServer install: Lang Encoding: en_US.UTF-8
PlexMediaServer install: Config file used: /etc/systemd/system/plexmediaserver.service.d/override.conf
PlexMediaServer install: Intel QSV Hardware: Not found
PlexMediaServer install: OpenCL library: Installed
PlexMediaServer install: Beignet package: Installed
PlexMediaServer install: Completing final configuration.
PlexMediaServer install: Starting Plex Media Server.
PlexMediaServer install: PlexMediaServer-1.21.1.3842-b0c7a97d9 - Installation successful. Errors: 0, Warnings: 0
I think I just need to change Lang Encoding: en_US.UTF-8 to Lang Encoding: fr_FR.UTF-8
How can I do that please?
tomtom
Why do you think you have to do that?
Because I have this problem on French subtitles only, but it’s my best clue, if you have any other idea I’m listening
What kind of subtitles are you using? External or embedded?
If external, could you zip one example and send it to me?
It happen only with external subtitles, mostly grabbed on Addic7ed.comShameless (US) - 11x04 - NIMBY.GGEZ.French.C.updated.Addic7ed.com.zip (32.2 KB)
See if anything changes if you use this version: Shameless (US) - 11x04 - NIMBY.GGEZ.French.C.updated.Addic7ed.com.fre.srt.zip (30.7 KB)
