I canât believe it. After everything I did it turns out the problem is between the ISP/Plex/Themoviedb
I tried refreshing all metadata using a LTE modem, and it worked fine.
@âMaximiliano Fernandezâ
Have a look at your wireshark to compare a sequence for a request that terminates ok with an HTTP OK 200 response and one that does not and see if it is the same as what was in wireshark from @gonse
See http://forums.plex.tv/discussion/comment/1653848/#Comment_1653848
Remove your http filter and replace with a filter for the source port for the GET request - eg port == 11166 in the example I had (that would pick all packets with either source port or destination port equals 11166
Same issue. Live in Argentina, using Fibertel/Cablevision, and itâs impossible to fetch metadata. Timed out requests over and over againâŠ
I donât have a wifi adapter in this computer so canât test with an LTE connection. But what about a proxy? That should work, but when I enable a proxy on Windows settings I get lots of âHTTPError: HTTP Error 403: Target service not allowedâ in my PMS log.
@sa2000, there has to be a way to make this work and bypass Fibertel!
Alright, I tried the LTE connection via Bluetooth and can confirm fetching metadata works. However, this isnât feasible for maintaining the entire library. We really need a solution for Argentina, Fibertel is the largest ISP!
I have discussed with our operations team and I am afraid this between the ISP and Cloudflare / tmdb
The cloudflare is for tmdb and not one arranged by Plex - any issue probably best to raise with the ISP in first instance
What about the proxy solution, @sa2000? It does improve fetching metadata, but it raises other problems. For example, when a proxy is enabled, the server isnât found when I browse app.plex.tv â it does if I login via localhost 127.0.0.1:32400.
However, something else fails because of the repeated Target service not allowed errors. Iâm assuming my PMS canât be accessed from the outside when a proxy is enforced. Any ideas?
I am afraid there are always issues with the operation of Plex Media Server and the python agent and system bundle processes when there is a proxy. You can search the support articles and you will see that proxy crops up in many cases as something to check https://support.plex.tv/articles/?s=proxy&search=support_articles
I donât have any info on this. It is between tmdb, cloudflare and ISP - there is no Plex involvement with how tmdb setup their data and the use of cloudflare is by them rather than plex
With regards to use of proxy, i mentioned that proxy software is known to cause probelms with operation of Plex Media Server. Heppy to look at logs but
The problem is being investigated by tmdb / cloudflare - they have asked for anyone with the issue to provide the output from this request https://image.tmdb.org/cdn-cgi/trace
I think I qualify for the same issue: Ubuntu Server + plex & IPv6 disabled & Argentina & Fibertel & timeout on TMDB. Seems not solved. It may be because of the Technicolor DPC3848VE modem from Fibertel.
I have the issue too, but I donât use the Technicolor cablemodem as router, mine is in bridge mode and I have a pfSense as firewall router. with the public IP address.
