Hello,
as stated in the object, after restarting Plex after hanging without any reasons, I checked the Media Server.log file and there seems to be some problems with the connection to some “SubManager”. Plus the web interface keeps loading without showing any page.
Here’s the relevant part of the log:
Jul 24, 2018 11:35:26.117 [0x7f02bc7fe700] WARN - PubSubManager: Connection to 82.94.168.55 failed: Connection timed out.
Jul 24, 2018 11:35:26.117 [0x7f02bc7fe700] WARN - PubSubManager: Connection to 50.116.44.223 failed: Connection timed out.
Jul 24, 2018 11:35:26.117 [0x7f02bc7fe700] WARN - PubSubManager: Connection to 45.79.11.43 failed: Connection timed out.
Jul 24, 2018 11:35:26.117 [0x7f02bc7fe700] WARN - PubSubManager: Connection to 172.104.24.90 failed: Connection timed out.
Jul 24, 2018 11:35:26.117 [0x7f02bc7fe700] WARN - PubSubManager: Connection to 172.104.133.220 failed: Connection timed out.
Jul 24, 2018 11:35:26.117 [0x7f02bc7fe700] WARN - PubSubManager: Connection to 139.162.115.125 failed: Connection timed out.
Jul 24, 2018 11:35:26.117 [0x7f02bc7fe700] WARN - PubSubManager: Connection to 178.79.150.155 failed: Connection timed out.
Jul 24, 2018 11:35:26.117 [0x7f02bc7fe700] WARN - PubSubManager: Connection to 172.104.173.210 failed: Connection timed out.
Jul 24, 2018 11:35:26.117 [0x7f02bc7fe700] WARN - PubSubManager: Connection to 184.105.148.98 failed: Connection timed out.
Jul 24, 2018 11:35:26.117 [0x7f02bc7fe700] WARN - PubSubManager: Connection to 82.94.168.60 failed: Connection timed out.
Jul 24, 2018 11:38:16.150 [0x7f02a6bf9700] ERROR - Timeout or error reading status line from plug-in pipe [com.plexapp.agents.imdb], we’re killing it.
Jul 24, 2018 11:38:16.150 [0x7f02a6bf9700] ERROR - Error received reading configuration for com.plexapp.agents.imdb
Jul 24, 2018 11:38:16.151 [0x7f02a6bf9700] ERROR - downloadContainer: expected MediaContainer element, found html
Jul 24, 2018 11:38:16.151 [0x7f02a6bf9700] ERROR - IVA: failed to get IMDB prefs
Plex is running on a Debian dedicated server with a 1Gbit full-duplex connection without any restriction. No UPnP problems as all ports are, like every dedicated servers, open.
Where is the section where PMS shows the ethernet adapters it finds in its startup scan?
Minimally it will report the loopback (lo) adapter at 127.0.0.1.
That’s missing.
Can you just go to Settings - Server - Help - Download Logs and attach the ZIP it gives you?
I’ll have the full view. It’ll be a lot easier than looking at snippets
I see two WAN IP addresses (Public Internet) defined. One is eth0, and the second is the alias address on eth0.1.
I’m also seeing Verbose logging. Can you turn that off please? We only use Verbose logging when there is need to see each individual mouse click or block of data sent to a player . It’s insanely verbose causing a lot of debugging data loss.
If this machine is in a datacenter (VPS, dedicated host, etc) then PMS is getting confused because of the routing (netstat -r).
PMS can’t decide, or has decided prematurely to select the wrong adapter due to startup delays of the host, nor is there any way to tell it, which adapter to use right now. One might be the hosting company’s internal net with no public route to pubsub (Publication Subsystem – how your server is registered as active in Plex.tv)
There is a change coming out in this next version which will finally give us that control in PMS. You will be able to tell it which ethernet adapter.
Do you find that sometimes it’s ok and other times it’s not?
Yes. Sometimes it just hangs, sometimes it streams just fine, sometimes it buffers, sometimes it’s unavailable from external network (red badge in the Network tab, although it’s perfectly accessible).
I’ll wait for the big change to come, hopefully it will fix all the issues i’m encountering!
Hello,
I’m sorry to tell you that even after the update, without any 2nd IP addresses, the problem persists and I can’t access Plex nor locally or remotely.
Same problem as already notified:
Aug 02, 2018 22:34:01.084 [0x7fed2dbfe700] WARN - PubSubManager: Connection to 139.162.115.125 failed: Connection timed out.
Aug 02, 2018 22:34:01.084 [0x7fed2dbfe700] WARN - PubSubManager: Connection to 139.162.195.42 failed: Connection timed out.
Aug 02, 2018 22:34:01.084 [0x7fed2dbfe700] WARN - PubSubManager: Connection to 139.162.54.192 failed: Connection timed out.
Aug 02, 2018 22:34:01.085 [0x7fed2dbfe700] WARN - PubSubManager: Connection to 184.105.148.102 failed: Connection timed out.
Aug 02, 2018 22:34:01.085 [0x7fed2dbfe700] WARN - PubSubManager: Connection to 82.94.168.47 failed: Connection timed out.
Aug 02, 2018 22:34:01.085 [0x7fed2dbfe700] WARN - PubSubManager: Connection to 82.94.168.55 failed: Connection timed out.
Aug 02, 2018 22:34:01.085 [0x7fed2dbfe700] WARN - PubSubManager: Connection to 45.79.197.109 failed: Connection timed out.
Aug 02, 2018 22:34:01.085 [0x7fed2dbfe700] WARN - PubSubManager: Connection to 45.33.118.95 failed: Connection timed out.
Aug 02, 2018 22:34:01.085 [0x7fed2dbfe700] WARN - PubSubManager: Connection to 172.104.216.121 failed: Connection timed out.
Aug 02, 2018 22:34:01.085 [0x7fed2dbfe700] WARN - PubSubManager: Connection to 172.104.133.220 failed: Connection timed out.
I ask this because we made changes at PubSub and since you have 2 WAN addresses directly connected, I need to see how that works. You might need to use the new PMS 1.13.5 ‘bind’ feature to select only 1 ( It prevents this situation from happening)
Currently there is no way for me to access the server via web interface, as it simply won’t load (restarted server, pms service, etc). Any way to enable the DEBUG logging via console?
I tunneled the port with PuTTY, PMS won’t answer and times out.
After 57 restarts of PMS I managed to enable the DEBUG logs, but I can’t download them.
I’ll just tar the “Logs” folder from the console and upload it.
If the pubsub timeouts you posted previously are from 1.13.4, we’d like to see them.
We do prefer you use 1.13.5 which has several changes including the ability to select which adapter to use when communicating with Plex.tc
I am concerned about the validity of the certificate you’re trying to install.
If you attempt to replace PMS’s cert with your own, PMS won’t work.
If you ADD your cert to PMS, validating both, it will work.
Can you validate your cert installation ?
Aug 03, 2018 01:16:31.422 [0x7f3a2ae49800] DEBUG - CERT: Installed certificate with fingerprint f9:85:54:bb:1b:8f:cb:66:fa:8d:82:ff:03:5e:9c:14:ac:b9:ef:7a.
Aug 03, 2018 01:16:31.422 [0x7f3a2ae49800] DEBUG - CERT: Installed new private key.
Aug 03, 2018 01:16:31.422 [0x7f3a2ae49800] DEBUG - CERT: Subject name is /C=US/ST=CA/L=Los Gatos/O=Plex, Inc./CN=*.dc346de1a61e4663a3a36ef907ec1954.plex.direct
Aug 03, 2018 01:16:31.422 [0x7f3a2ae49800] DEBUG - CERT: OCSP requests for stapling will be made to 'http://ocspx.digicert.com/'.
Aug 03, 2018 01:16:31.422 [0x7f3a2ae49800] INFO - OCSP: Successfully retrieved response from cache.
Aug 03, 2018 01:16:31.422 [0x7f3a2ae49800] DEBUG - CERT: Installed intermediate certificate.
Aug 03, 2018 01:16:31.423 [0x7f3a2ae49800] DEBUG - CERT: Loaded a user-provided certificate.
Aug 03, 2018 01:16:31.423 [0x7f3a2ae49800] WARN - CERT: Missing cert or issuer; skipping OCSP stapling
Aug 03, 2018 01:16:31.424 [0x7f3a2ae49800] DEBUG - HttpServer: Listening on port 32400 with queue of 128 connections.
Aug 03, 2018 01:16:31.424 [0x7f3a2ae49800] DEBUG - HttpServer: Listening on port 32401 with queue of 128 connections.
Aug 03, 2018 01:16:31.427 [0x7f3a1afff700] DEBUG - DVR:Grabber: Cleaning up orphaned grabs.
Aug 03, 2018 01:16:31.427 [0x7f3a2ae49800] DEBUG - Media Provider: Registering provider com.plexapp.plugins.library
Aug 03, 2018 01:16:31.427 [0x7f3a2ae49800] DEBUG - Auth: Refreshing tokens inside the token-based authentication filter.
Aug 03, 2018 01:16:31.427 [0x7f3a2ae49800] DEBUG - Relay: read 10 cached entries from hosts file
I’m wondering if PMS might not be handling certification failure fallback
