Plex Transcoder Errors: Connection Failed and Access Denied Issues
Server Version#: 1.41.3.9314
Player Version#: Chrome
Hi Plex Support and Community,
I’m experiencing recurring issues with Plex transcoding, and I’m unsure how to resolve them. Essentially, when a stream is running it’ll exit with the error to a user saying “Conversion failed. The transcoder exited due to an error”
Below are the details of the errors and my current settings:
Error Logs:
Feb 05, 2025 21:55:00.555 [26024] ERROR - [Req#146c2/Transcode/FA02CE85-E50A-4711-9FD8-51C7923A352B/6cea6688-0529-4404-86ee-53dd9170421d] [tcp @ 0000028ddf6bc3c0] Connection to tcp://127.0.0.1:32400 failed: Error number -10055 occurred
Feb 05, 2025 21:55:00.556 [26024] ERROR - [Req#146c5/Transcode/FA02CE85-E50A-4711-9FD8-51C7923A352B/6cea6688-0529-4404-86ee-53dd9170421d] [stream_segment,ssegment @ 0000028de0328e80] Failed to open segment list 'http://127.0.0.1:32400/video/:/transcode/session/FA02CE85-E50A-4711-9FD8-51C7923A352B/6cea6688-0529-4404-86ee-53dd9170421d/manifest?X-Plex-Http-Pipeline=infinite'
Feb 05, 2025 21:55:00.556 [26024] ERROR - [Req#146c6/Transcode/FA02CE85-E50A-4711-9FD8-51C7923A352B/6cea6688-0529-4404-86ee-53dd9170421d] av_interleaved_write_frame(): Unknown error
Feb 05, 2025 21:55:00.644 [7756] ERROR - Session 0000012163310480 terminated
Feb 05, 2025 21:55:00.647 [26980] ERROR - Transcoder: Failed to delete session directory (boost::filesystem::remove_all: Access is denied [system:5]: "G:\Plex Transcoder\Transcode\Sessions\plex-transcode-FA02CE85-E50A-4711-9FD8-51C7923A352B-6cea6688-0529-4404-86ee-53dd9170421d\media-00003.ts")
Feb 05, 2025 21:55:03.474 [29068] WARN - [Req#14719/Transcode] Got a request to stop a transcode session without a valid session GUID.
I’d appreciate any guidance or recommendations to resolve these issues. Is there something I’ve misconfigured, or are there additional settings I should adjust?
Thanks in advance!
Update to the latest server version.
What type of drive is G:?
Have you instructed the anti virus software to not stick its nose into the transcoder temp folder?
Definitely recommend, otherwise it could try and look for malware in each of the transcoded media chunks.
