Plex transcodes video when transcoding audio and using subtitles
Server Version#: 1.31.3.6868
Player Version#: 5.59.3
Plex Media Server Logs_2023-04-23_12-39-38.zip (264.3 KB)
Context:
The LG C2 supports AC3 but does not support DTS audio.
Plex for LG supports PGS subtitles natively.
Reproduction steps:
  1. Play a file with DTS audio and no subtitles
  2. Play a file with DTS audio and PGS subtitles
  3. Play a file with AC3 audio and PGS subtitles
Actual results:
  1. Only audio is transcoded
  2. Both video and audio are transcoded
  3. Nothing is transcoded
Expected results:
  2. Only audio is transcoded
See here:
Can you verify #3?
TrueHD audio, with or without subtitles, should be transcoded by Plex Media Server.
TrueHD is not listed as a supported audio format in the C2 specs (LG).
No known TV, LG or other, supports passthrough of TrueHD audio from a TV based app.
The C2 will passthrough TrueHD from a device attached to an HDMI input, but TrueHD audio from a TV based app should transcode.
You’re right. It had actually selected the AC3 track. I have edited the first post.
My point was that the app does not transcode just because of subtitles.
Thanks for verifying.
Yes. It is subtitles + direct streaming. It has been that way for a long time, at least since I bought my B7 OLED several years ago. Hopefully some day Plex can get it working w/o video transcoding.
