Plex transcoding audio to opus when requesting video transcoding
Trying to understand what is happening.
I am using a firestick max 4k and am streaming from plex server on linux Version 1.32.6.7371
I have the video encoded at 4k h.265 10 bit in mkv format I have AC3 audio included in the stream.
I can direct play the 4k video along with the AC3 audio just fine. When I choose a lower quality 1080p video stream I expect the video to HW transcode and the audio to continue to direct stream. However the audio is transcoding to OPUS. trying to understand why?
plexlog.zip (23.9 KB)
It’s an intended behavior, because otherwise on some devices audio video sync can drift apart over time.
So anytime the video transcodes we should expect the audio to transcode to opus? Is opus the only option? Is it 2 channel opus even if the original stream is 6 channel?
Opus is used because it delivers the highest quality at very low bitrates.
If you pick a higher target bandwidth, you can get also higher audio data rates. Depending on the player device, this can also mean 6-channel sound.
The reasons for transcoding according to your log are:
  • audio has 8 channels, while your device only supports 6
  • the selected audio track is not the first audio track within the source file
Actually aware of the 8 channel vs 6 channel issue. However I specifically changed to the 6 channel audio stream after the video had started. So you should see it go from 8 channel TrueHD to 6 channel AC3 audio. I then manually change the video quality from 4K to 1080 to force a HW transcode.
I’m not stating anything is wrong here just trying to understand why it does what it does. Thank you!
