I’m wondering why Plex has to transcode audio from my 4K movie when I changed audio. For example from English to Polish. Of course video has multiple language audio track.
Thanks for reply.
Which client type?
Where are you reading ‘transcoding’?
I am trying to watch movie on Samsung TV.
I read transcoding on plex server and my CPU Intel 4770 has problem to transcode.
Are you using subtitles?
Yes, I am using.
Then you cannot use 4K on your TV with the file you have.
As soon as you have both subtitles activated and you choose a different audio track than the first in the file, Plex will transcode the file.
This is a workaround because otherwise video and audio will “drift” apart and synchronicity cannot be maintained.
All you can do is to:
- convert the subtitle into SRT format
- remux the video file, so your desirted audio track is the first audio track.
see also Plex, 4k, transcoding, and you - aka the rules of 4k - a FAQ
