Plex Translations
Hello, can someone tell me how I can query all translations?
https://app.plex.tv/desktop/translations/de.json
Would you like to query them via a url, or are they in the Plex server folder?
Thank you
Why would you need to?
I want to revise my PlexDream plugin.
https://sites.google.com/view/made-by-boxpirates-plugins/made-by-boxpirates/movie-serien-plugins/plexdream
I’m in the process of adding more features.
It is certainly possible to query them all via the above URL, just replacing the language code.
These are the strings of the web app only. (which is the most extensive app, so you should be able to find all the strings you need. But I can’t tell you which string is actually for which place in the app.)
Plex brings its local version of the web app, so in theory you should be able to fetch them from there as well.
Which languages are actually available, you can probably gather from the translation project on Transifex. https://support.plex.tv/articles/translations-and-localization/
Thanks, yes, that’s how I get ahead.
I only need certain translations, which I can then look for.
For this I have scripts for methen create new xxx.json, which I can then add to the plugin.
Wanted to add the translation right away, because I’m working on a big update at the moment.
Thanks again
