Server Version#: 1.24.4.5081
Player Version#: Web 4.68.0
Even after multiple server updates, Plex TV Series does not show up under Agents. What am I missing here?
Please restart your server, wait a few minutes and then grab the server logs and post them here.
Plex Media Server Logs_2021-10-22_11-23-27.zip (4.8 MB)
Thank you. Here are the logs.
Thanks.
That’s a bit strange, I can’t really make out why that’s happening.
Could you run the following command from the terminal for me and post the output.
ls -Ral /usr/lib/plexmediaserver/Resources/Plug-ins-e362dc1ee/PlexSeries.bundle
/usr/lib/plexmediaserver/Resources/Plug-ins-e362dc1ee/PlexSeries.bundle:
total 12
drwxr-xr-x 3 root root 4096 Oct 14 18:35 .
drwxr-xr-x 24 root root 4096 Oct 14 18:35 ..
drwxr-xr-x 4 root root 4096 Oct 14 18:35 Contents
/usr/lib/plexmediaserver/Resources/Plug-ins-e362dc1ee/PlexSeries.bundle/Contents:
total 28
drwxr-xr-x 4 root root 4096 Oct 14 18:35 .
drwxr-xr-x 3 root root 4096 Oct 14 18:35 ..
drwxr-xr-x 2 root root 4096 Oct 14 18:35 Code
-rw-rw-r-- 1 root root 4 Sep 24 10:24 DefaultPrefs.json
-rw-rw-r-- 1 root root 480 Sep 24 10:24 Info.plist
drwxr-xr-x 2 root root 4096 Oct 14 18:35 Resources
-rw-r--r-- 1 root root 39 Sep 24 10:24 VERSION
/usr/lib/plexmediaserver/Resources/Plug-ins-e362dc1ee/PlexSeries.bundle/Contents/Code:
total 12
drwxr-xr-x 2 root root 4096 Oct 14 18:35 .
drwxr-xr-x 4 root root 4096 Oct 14 18:35 ..
-rw-rw-r-- 1 root root 173 Sep 24 10:24 __init__.py
/usr/lib/plexmediaserver/Resources/Plug-ins-e362dc1ee/PlexSeries.bundle/Contents/Resources:
total 100
-rw-rw-r-- 1 root root 91315 Sep 24 10:24 icon-default.png
Thanks, that all looks correct.
I can’t really tell what could be going wrong there. You could try removing Plex completely and re-installing it. I’ll see if I can figure something out on Monday.
Thanks, no worries. Let me know. I’d rather not take such a drastic step if I don’t have to.
Enjoy your weekend.
@drzoidberg33 Were you able to figure this one out? If not, what’s the proper procedure to reinstall Plex on Linux and not have to reconfigure everything?
@drzoidberg33 I have updated to Version 1.24.5.5173 and still nothing. I’m just doing a dpkg -i ./file Any further suggestions here? Thank you.
Running dpkg -r plexmediaserver, the renaming “/var/lib/plexmediaserver/Library/Application Support/Plex Media Server/” “Fixed” the issue. Serious pain in the ass to set everything back up. I hope you can find a solution to this for other users who may have this issue.
Is there any way to get my history back by copying something from the old directory into the new? My DVR schedules? etc?
Ok, update. So, after the reinstall, i copied the new PlexSeries.bundle from the new /usr/lib/plexmediaserver/Resources/Plug-ins-xxxxxxx directory to my old Plug-ins-e362dc1ee directory, changed permissions, then renamed “/var/lib/plexmediaserver/Library/Application Support/Plex Media Server/” to .NEW and restored my "“/var/lib/plexmediaserver/Library/Application Support/Plex Media Server/” directory, and it appears to have the Plex TV Series Agent now.
