Server Version#:1.22.2.4282
Player Version#:n/a
I’ve been using Plex for years, and TV Matching has always worked perfectly. Recently though new shows are not being matched. When I try to “Match…” or even “Fix Match…” the only agent show in the Agent dropdown is the “Home Movie Series”. Also NO RESULTS are ever found…
When I got to a library and choose Manage → Advanced at the Scanner is “Plex Series Scanner” (which is the “old” scanner) but I do have the choice for the newer “Plex TV Series” scanner. If I choose that and click “Save Change” it tells me that “Your changes could not be saved.”
Please help, not matching shows is driving me crazy!
How many TV show agents are listed under
Settings - Server - Agents - Shows
e.g.
I followed those steps, did the uninstall from Add/Remove programs, rebooted, reinstalled with the latest download 1.22.2.4282 and it still only has those options in the Agents section of the server. (Previously I also had tried to repair but that had no effect either)
Are you using a 3rd-party anti virus software?
Which web browser are you using, and which browser add-ins are activated in it?
Is there a VPN software involved?
Please check your Plex server database for damage:
activate debug logging (not ‘verbose’!)
- quit Plex Server
- wait 1 minute
- start Plex Server
- wait 5 minutes
fetch log files and attach them here
Or inspect them yourself. Take a look at the Plex Media Server.log file and seek for messages about database corrupt or malformed.
If you find these, you may have to repair your database.
Plex Media Server Logs_2021-04-15_03-46-24.zip (3.1 MB)
Using Windows AV, No VPN, Tried in Chrome/IE/Firefox (no difference)
I couldn’t find any signs of database damage in your logs.
Have you in any way modified the firewall settings of Windows?
Is your Windows running in protected mode?
How much free space is left on drive C: ?
Are there any other configuration changes (away from default) or additional software in place to make the system “more secure”?
Nope to changing firewall settings, firewall is actually disabled on my Windows 10 PC. Windows is not running in protected mode. 27.6 GB free on C drive. Plex has been running fine for a long time, used to have all those other agents…this probably came with one of the recent Plex upgrades but I don’t know exact when it started.
Take a look into %LOCALAPPDATA%\Plex Media Server\Updates and see if you have an earlier version of the Plex server installer in there.
Try to revert back, see it this is restoring the additional agents.
Tried uninstalling, rebooting, going back to a previous version. Same issue.
Tried uninstalling, rebooting, installed latest version (again). Same issue.
Uninstalled, then manually cleaned up and directory and registry entry. Rebooted. Reinstalled latest version. Same issue.
