Plex TV with Fritz!Box DVB-C
Server Version#: 1.23.3.4706
Player Version#: Web
Tuner Make/Model: Fritz!Box 6490 Cable DVB-C
Guide/Lineup name:
Using XMLTV?: No
Jun 17, 2021 17:22:58.096 [0x7f55717eeb38] INFO - [I] device_manager_t::get_device_list. Device FRITZ!Box 6490 Cable (kdg) (200.1.1.1) - 0, id dvb#sat2ip#0#uuid:663d5d6c-f9f8-4bb4-84d4-444E6D4EEBAF, tuners 1, state 0, standards 2
Jun 17, 2021 17:22:58.096 [0x7f55717eeb38] INFO - [I] device_manager_t::get_device_list. Device FRITZ!Box 6490 Cable (kdg) (200.1.1.1) - 1, id dvb#sat2ip#1#uuid:663d5d6c-f9f8-4bb4-84d4-444E6D4EEBAF, tuners 1, state 0, standards 2
Jun 17, 2021 17:22:58.096 [0x7f55717eeb38] INFO - [I] device_manager_t::get_device_list. Device FRITZ!Box 6490 Cable (kdg) (200.1.1.1) - 2, id dvb#sat2ip#2#uuid:663d5d6c-f9f8-4bb4-84d4-444E6D4EEBAF, tuners 1, state 0, standards 2
Jun 17, 2021 17:22:58.096 [0x7f55717eeb38] INFO - [I] device_manager_t::get_device_list. Device FRITZ!Box 6490 Cable (kdg) (200.1.1.1) - 3, id dvb#sat2ip#3#uuid:663d5d6c-f9f8-4bb4-84d4-444E6D4EEBAF, tuners 1, state 0, standards 2
Jun 17, 2021 17:22:58.097 [0x7f55716ebb38] INFO - [I] web_service_t::process_device_status
Jun 17, 2021 17:22:58.097 [0x7f55716ebb38] INFO - [I] sat2ip_tuner_factory_t::get_tuner_info. device uuid:663d5d6c-f9f8-4bb4-84d4-444E6D4EEBAF, frontend index 0
Jun 17, 2021 17:22:58.097 [0x7f55716ebb38] INFO - [I] SAT2IP - get_device_ip_by_device_path()
Jun 17, 2021 17:22:58.099 [0x7f55716ebb38] INFO - [I] SAT2IP - new_server_callback: found sat2ip server uuid:663d5d6c-f9f8-4bb4-84d4-444E6D4EEBAF at 200.1.1.1
Jun 17, 2021 17:22:58.103 [0x7f55719f4b38] INFO - [I] web_service_t::process_get_scanners
Jun 17, 2021 17:22:58.103 [0x7f55719f4b38] INFO - [I] sat2ip_tuner_factory_t::get_tuner_info. device uuid:663d5d6c-f9f8-4bb4-84d4-444E6D4EEBAF, frontend index 0
Jun 17, 2021 17:22:58.104 [0x7f55719f4b38] INFO - [I] SAT2IP - get_device_ip_by_device_path()
Jun 17, 2021 17:22:58.105 [0x7f55719f4b38] INFO - [I] SAT2IP - new_server_callback: found sat2ip server uuid:663d5d6c-f9f8-4bb4-84d4-444E6D4EEBAF at 200.1.1.1
Jun 17, 2021 17:22:58.122 [0x7f5571cffb38] INFO - [I] web_service_t::process_device_status
Jun 17, 2021 17:22:58.122 [0x7f5571cffb38] INFO - [I] sat2ip_tuner_factory_t::get_tuner_info. device uuid:663d5d6c-f9f8-4bb4-84d4-444E6D4EEBAF, frontend index 0
Jun 17, 2021 17:22:58.122 [0x7f5571cffb38] INFO - [I] SAT2IP - get_device_ip_by_device_path()
Jun 17, 2021 17:22:58.124 [0x7f5571cffb38] INFO - [I] SAT2IP - new_server_callback: found sat2ip server uuid:663d5d6c-f9f8-4bb4-84d4-444E6D4EEBAF at 200.1.1.1
Jun 17, 2021 17:22:58.130 [0x7f55716ebb38] INFO - [I] web_service_t::process_get_scanners
Jun 17, 2021 17:22:58.130 [0x7f55716ebb38] INFO - [I] sat2ip_tuner_factory_t::get_tuner_info. device uuid:663d5d6c-f9f8-4bb4-84d4-444E6D4EEBAF, frontend index 0
Jun 17, 2021 17:22:58.130 [0x7f55716ebb38] INFO - [I] SAT2IP - get_device_ip_by_device_path()
Jun 17, 2021 17:22:58.132 [0x7f55716ebb38] INFO - [I] SAT2IP - new_server_callback: found sat2ip server uuid:663d5d6c-f9f8-4bb4-84d4-444E6D4EEBAF at 200.1.1.1
Jun 17, 2021 17:23:00.895 [0x7f5571af7b38] INFO - [I] web_service_t::process_get_scanners
Jun 17, 2021 17:23:00.895 [0x7f5571af7b38] INFO - [I] sat2ip_tuner_factory_t::get_tuner_info. device uuid:663d5d6c-f9f8-4bb4-84d4-444E6D4EEBAF, frontend index 0
Jun 17, 2021 17:23:00.895 [0x7f5571af7b38] INFO - [I] SAT2IP - get_device_ip_by_device_path()
Jun 17, 2021 17:23:00.898 [0x7f5571af7b38] INFO - [I] SAT2IP - new_server_callback: found sat2ip server uuid:663d5d6c-f9f8-4bb4-84d4-444E6D4EEBAF at 200.1.1.1
I try to do a channel search. But I just can click the button and nothing happens. Above logs it produces…
hey there,
i get the same error when i use the web interface. You can use a workaround if you use the plex app on your system. With the app you can start the scan :slight_smile:
Thanks for the answer! It works now…
Just got a new problem: It finds radio stations only… I did try to write an own .ini according to my cable frequences… But problem still exists… damn it.
