I Can confirm that its back up for remote users as well
time ![]()
Mine is still down. And even more annoyingly I canāt even access it locally. It just says plex is down for maintenance. Surely access to my server locally (on localhost) shouldnāt depend on plex.tv.
All, please restart your PMS, and hopefully, should be fixed
I cannot yet find what I have but did find similar here.
slaps self for being OFF-TOPIC ![]()
@ChuckPa I see some spending in my futureā¦
Thanks!
muahahahahahah ![]()
Thanks! Oh, and my remote access is working again too!
To Ops, something something monitoring ![]()
@ChuckPa ā¦thanks for keeping us informed. I, like many others, was pulling out my hair wondering what the heck i mustāve done wrong.
Questionā¦so although PMS appears to be back, I can only play āsomeā content (smaller files) over the WAN ⦠And the Remote access page is still reporting that Plex is āNot available outside your networkā.
Any advice? (Running PMS via a container in Docker on a Synology NAS.
Thanks in advance. (Enjoy the wine time)
Have you restarted PMS since the partial outage ?
I say this because, PMS contacts Plex.tv each time it starts.
If it could not get its IP address (where the problem was),
Then Plex.tv would not have a valid IP address to give the clients to use when they want to start playback
Given you say āsmaller filesā, I am curious about this.
Might you have DEBUG logging enabled and can capture a failure of a normal file for me?
I donāt think smaller vs normal files is at all outage related
Hey Chucks
Was just about to. Hoping that resolves the issue.
Cheersā¦
ChuckPa/ALLā¦
I got to the bottom of the issue.
I have a Synology DS918+ and recently had to move my WHOLE operation from a Mac Mini iād been using which served me faithfully for 10 Plus yearsā¦
My searching, indexing, acquisition, organisation and monitoringā¦all moved to Synology under the DOCKER-Container system. A lot of learning and seeking adviceā¦
Anywayā¦found out the reason behind the lack of WAN connectivityā¦it was the fact that despite having created the relevant port forwarding rule on my ASUS router for PLEXā¦I had to in like manner create an equivalent one as a firewall rule on the Synology effectively allowing port 32400 to pass ⦠so in essenceā¦that port needed opening/forwarding on BOTH the Router AND the Synology within itās firewall rules.
Soon as i did thatā¦BANGā¦FIRING on all cylinders and advertising to the world.
Hope this helps at least one person with a similar set up who may find themselves in this kind of situationā¦
Now i have to optimise the settings in Plex as the CPU load is super highā¦even with just two streamsā¦
