Server Version#: 1.19.5.3112
Player Version#: 7.4 (iOS 14.0, iOS 12.4.8)
Plex is unable to sync certain items to my mobile iOS devices, always returning “The transcoder encountered an error.”
The Logs return the following:
Aug 20, 2020 12:06:37.079 [0x70000f56f000] Error — [Transcoder] [matroska @ 0x7fa889043e00] Subtitle codec 94213 is not supported.
Aug 20, 2020 12:06:37.079 [0x70000f56f000] Error — [Transcoder] av_interleaved_write_frame(): Function not implemented
Aug 20, 2020 12:06:37.079 [0x70000f56f000] Error — [Transcoder] Error writing trailer of /Users/mgoeppl/Library/Caches/PlexMediaServer/Transcode/Sync+/46606589/f7/275418.mkv.temp: Function not implemented
Aug 20, 2020 12:06:37.079 [0x70000f56f000] Debug — Streaming Resource: Unthrottling session 0x7fccb197f848:9772ce9f-aee9-4ee8-9982-e3b2f0fcc78d which is using static transcoder slot. Used slots is now 5
Aug 20, 2020 12:06:37.081 [0x70000d8c7000] Debug — Jobs: ‘/Applications/Plex Media Server.app/Contents/MacOS/Plex Transcoder’ exit code for process 5653 is 1 (failure)
Aug 20, 2020 12:06:37.082 [0x70000d11a000] Debug — Transcoder: Cleaning old transcode directories.
Aug 20, 2020 12:06:37.082 [0x70000e50f000] Debug — Streaming Resource: Terminating session 0x7fccb197f848:9772ce9f-aee9-4ee8-9982-e3b2f0fcc78d which is using static transcoder slot. Used slots is now 4
Aug 20, 2020 12:06:37.082 [0x70000e50f000] Debug — Streaming Resource: Terminated session 0x7fccb197f848:9772ce9f-aee9-4ee8-9982-e3b2f0fcc78d with reason Conversion failed. The transcoder exited due to an error.
Aug 20, 2020 12:06:37.085 [0x70000d19d000] Debug — Auth: authenticated user 1 as MGoeppl
Aug 20, 2020 12:06:37.085 [0x70000f56f000] Debug — Request: [10.0.0.91:52856 (Allowed Network (Subnet))] GET /status/sessions/background (12 live) TLS GZIP Signed-in Token (MGoeppl)
Aug 20, 2020 12:06:37.086 [0x70000d73e000] Debug — Killing job.
Aug 20, 2020 12:06:37.086 [0x70000d73e000] Debug — Signalling job ID 5653 with 9
Aug 20, 2020 12:06:37.086 [0x70000d73e000] Debug — Job was already killed, not killing again.
Aug 20, 2020 12:06:37.086 [0x70000d73e000] Debug — Stopping transcode session 9772ce9f-aee9-4ee8-9982-e3b2f0fcc78d
Aug 20, 2020 12:06:37.086 [0x70000d2a3000] Debug — Completed: [10.0.0.91:52856] 200 GET /status/sessions/background (12 live) TLS GZIP 0ms 690 bytes (pipelined: 4)
Aug 20, 2020 12:06:37.088 [0x70000d73e000] Debug — Transcoder: Cleaning old transcode directories.
Aug 20, 2020 12:06:37.088 [0x70000d11a000] Debug — Transcoder: Cleaning old transcode directory: “~/Library/Caches/PlexMediaServer/Transcode/Sync/Transcode/Sessions/plex-transcode-9772ce9f-aee9-4ee8-9982-e3b2f0fcc78d-c1809992-9578-4de2-9700-2e04e299b1c4”
Aug 20, 2020 12:06:37.088 [0x70000d11a000] Debug — Whacked session 9772ce9f-aee9-4ee8-9982-e3b2f0fcc78d, 0 remaining.
Aug 20, 2020 12:06:37.089 [0x70000d11a000] Debug — MDE: Selected protocol http; container: mkv
Aug 20, 2020 12:06:37.089 [0x70000d11a000] Debug — MDE: analyzing media item 272649
Aug 20, 2020 12:06:37.089 [0x70000d11a000] Debug — MDE: E10 - The Cause the Cure: no direct play video profile exists for http/mp4/h264
Aug 20, 2020 12:06:37.089 [0x70000d11a000] Debug — MDE: E10 - The Cause the Cure: no direct play video profile exists for http/mp4/h264/aac
Aug 20, 2020 12:06:37.089 [0x70000d11a000] Debug — MDE: E10 - The Cause the Cure: non-selected embedded subtitle stream 581481 cannot be direct-played
Aug 20, 2020 12:06:37.089 [0x70000d73e000] Debug — Whacked session 9772ce9f-aee9-4ee8-9982-e3b2f0fcc78d, 0 remaining.
Aug 20, 2020 12:06:37.089 [0x70000d11a000] Debug — MDE: E10 - The Cause the Cure: selected media 0 / 272649
Aug 20, 2020 12:06:37.089 [0x70000d11a000] Warning — TranscodeJobManager: previous hardware transcoding job failed, retrying with software transcoding
Aug 20, 2020 12:06:37.089 [0x70000d11a000] Debug — Cleaning directory for session 9772ce9f-aee9-4ee8-9982-e3b2f0fcc78d ()
Aug 20, 2020 12:06:37.089 [0x70000d11a000] Debug — Cleaning directory for session 9772ce9f-aee9-4ee8-9982-e3b2f0fcc78d (~/Library/Caches/PlexMediaServer/Transcode/Sync/Transcode/Sessions/plex-transcode-9772ce9f-aee9-4ee8-9982-e3b2f0fcc78d-c1809992-9578-4de2-9700-2e04e299b1c4)
Aug 20, 2020 12:06:37.089 [0x70000d11a000] Debug — Streaming Resource: Removing session 0x7fccb197f848:9772ce9f-aee9-4ee8-9982-e3b2f0fcc78d
Aug 20, 2020 12:06:37.089 [0x70000d11a000] Debug — Starting a transcode session 9772ce9f-aee9-4ee8-9982-e3b2f0fcc78d at offset -1.0 (state=3)
Aug 20, 2020 12:06:37.089 [0x70000d11a000] Debug — Streaming Resource: Added session 0x7fccb6fd5418:9772ce9f-aee9-4ee8-9982-e3b2f0fcc78d
Aug 20, 2020 12:06:37.090 [0x70000d11a000] Debug — TPU: hardware transcoding: enabled, but no hardware decode accelerator found
Aug 20, 2020 12:06:37.090 [0x70000d11a000] Debug — [Universal] Using local file path instead of URL: /Volumes/Media/Apple TV/Media/TV Shows/I May Destroy You/Season 1/1-10 The Cause the Cure (HD).mp4
Aug 20, 2020 12:06:37.090 [0x70000d11a000] Debug — TPU: hardware transcoding: final decoder: , final encoder:
Aug 20, 2020 12:06:37.091 [0x70000d11a000] Debug — Job running: EAE_ROOT=’/var/folders/kz/qz4__sfn7lg2924pvyftcp8c0000gn/T/PlexUpdater-1cf74a77-60b9-48c0-b7f6-c8b0a9623ece/pms-346e4452-218f-4651-8461-d550d4fa66af/EasyAudioEncoder’ FFMPEG_EXTERNAL_LIBS=’/Users/mgoeppl/Library/Application\ Support/Plex\ Media\ Server/Codecs/5f603a2-3204-darwin-x86_64/’ X_PLEX_TOKEN=‘xxxxxxxxxxxxxxxxxxxx’ ‘/Applications/Plex Media Server.app/Contents/MacOS/Plex Transcoder’ ‘-codec:#0x01’ ‘h264’ ‘-noaccurate_seek’ ‘-analyzeduration’ ‘20000000’ ‘-probesize’ ‘20000000’ ‘-i’ ‘/Volumes/Media/Apple TV/Media/TV Shows/I May Destroy You/Season 1/1-10 The Cause the Cure (HD).mp4’ ‘-map’ ‘0:#0x01’ ‘-codec:0’ ‘copy’ ‘-map’ ‘0:#0x02’ ‘-metadata:s:1’ ‘language=eng’ ‘-codec:1’ ‘copy’ ‘-map’ ‘0:#0x03’ ‘-metadata:s:2’ ‘language=eng’ ‘-codec:2’ ‘copy’ ‘-f’ ‘matroska’ ‘-map_metadata’ ‘-1’ ‘-map_chapters’ ‘-1’ ‘/Users/mgoeppl/Library/Caches/PlexMediaServer/Transcode/Sync+/46606589/f7/275418.mkv.temp’ ‘-y’ ‘-nostats’ ‘-loglevel’ ‘quiet’ ‘-loglevel_plex’ ‘error’ ‘-progressurl’ ‘http://127.0.0.1:32400/video/:/transcode/session/9772ce9f-aee9-4ee8-9982-e3b2f0fcc78d/ffa30517-df48-4ccd-9acd-735a20cd4041/progress’
Aug 20, 2020 12:06:37.093 [0x70000d11a000] Debug — Jobs: Starting child process with pid 5654
Aug 20, 2020 12:06:37.111 [0x70000f56f000] Debug — Request: [127.0.0.1:64345 (Loopback)] PUT /video/:/transcode/session/9772ce9f-aee9-4ee8-9982-e3b2f0fcc78d/ffa30517-df48-4ccd-9acd-735a20cd4041/progress?status=startup (13 live) Signed-in Token (MGoeppl) (range: bytes=0-)
Aug 20, 2020 12:06:37.111 [0x70000d2a3000] Debug — Completed: [127.0.0.1:64345] 204 PUT /video/:/transcode/session/9772ce9f-aee9-4ee8-9982-e3b2f0fcc78d/ffa30517-df48-4ccd-9acd-735a20cd4041/progress?status=startup (13 live) 0ms 203 bytes (pipelined: 1) (range: bytes=0-)
Aug 20, 2020 12:06:37.127 [0x70000f56f000] Debug — Request: [127.0.0.1:64345 (Loopback)] PUT /video/:/transcode/session/9772ce9f-aee9-4ee8-9982-e3b2f0fcc78d/ffa30517-df48-4ccd-9acd-735a20cd4041/progress?status=startup (13 live) Signed-in Token (MGoeppl) (range: bytes=0-)
Aug 20, 2020 12:06:37.128 [0x70000d2a3000] Debug — Completed: [127.0.0.1:64345] 204 PUT /video/:/transcode/session/9772ce9f-aee9-4ee8-9982-e3b2f0fcc78d/ffa30517-df48-4ccd-9acd-735a20cd4041/progress?status=startup (13 live) 0ms 203 bytes (pipelined: 2) (range: bytes=0-)
Aug 20, 2020 12:06:37.128 [0x70000f56f000] Debug — Request: [127.0.0.1:64345 (Loopback)] PUT /video/:/transcode/session/9772ce9f-aee9-4ee8-9982-e3b2f0fcc78d/ffa30517-df48-4ccd-9acd-735a20cd4041/progress?status=opening (13 live) Signed-in Token (MGoeppl) (range: bytes=0-)
Aug 20, 2020 12:06:37.128 [0x70000d19d000] Debug — Completed: [127.0.0.1:64345] 204 PUT /video/:/transcode/session/9772ce9f-aee9-4ee8-9982-e3b2f0fcc78d/ffa30517-df48-4ccd-9acd-735a20cd4041/progress?status=opening (13 live) 0ms 203 bytes (pipelined: 3) (range: bytes=0-)
Aug 20, 2020 12:06:37.145 [0x70000f56f000] Debug — Request: [127.0.0.1:64345 (Loopback)] PUT /video/:/transcode/session/9772ce9f-aee9-4ee8-9982-e3b2f0fcc78d/ffa30517-df48-4ccd-9acd-735a20cd4041/progress?status=opened (13 live) Signed-in Token (MGoeppl) (range: bytes=0-)
Aug 20, 2020 12:06:37.145 [0x70000d2a3000] Debug — Completed: [127.0.0.1:64345] 204 PUT /video/:/transcode/session/9772ce9f-aee9-4ee8-9982-e3b2f0fcc78d/ffa30517-df48-4ccd-9acd-735a20cd4041/progress?status=opened (13 live) 0ms 203 bytes (pipelined: 4) (range: bytes=0-)
Aug 20, 2020 12:06:37.145 [0x70000f56f000] Debug — Request: [127.0.0.1:64345 (Loopback)] PUT /video/:/transcode/session/9772ce9f-aee9-4ee8-9982-e3b2f0fcc78d/ffa30517-df48-4ccd-9acd-735a20cd4041/progress/stream?index=0&id=1&codec=h264&type=video (13 live) Signed-in Token (MGoeppl) (range: bytes=0-)
Aug 20, 2020 12:06:37.145 [0x70000d19d000] Debug — Completed: [127.0.0.1:64345] 200 PUT /video/:/transcode/session/9772ce9f-aee9-4ee8-9982-e3b2f0fcc78d/ffa30517-df48-4ccd-9acd-735a20cd4041/progress/stream?index=0&id=1&codec=h264&type=video (13 live) 0ms 195 bytes (pipelined: 5) (range: bytes=0-)
Aug 20, 2020 12:06:37.159 [0x70000f56f000] Debug — Request: [127.0.0.1:64345 (Loopback)] PUT /video/:/transcode/session/9772ce9f-aee9-4ee8-9982-e3b2f0fcc78d/ffa30517-df48-4ccd-9acd-735a20cd4041/progress/stream?index=1&id=2&codec=aac&type=audio&profile=LC (13 live) Signed-in Token (MGoeppl) (range: bytes=0-)
Aug 20, 2020 12:06:37.159 [0x70000d2a3000] Debug — Completed: [127.0.0.1:64345] 200 PUT /video/:/transcode/session/9772ce9f-aee9-4ee8-9982-e3b2f0fcc78d/ffa30517-df48-4ccd-9acd-735a20cd4041/progress/stream?index=1&id=2&codec=aac&type=audio&profile=LC (13 live) 0ms 195 bytes (pipelined: 6) (range: bytes=0-)
Aug 20, 2020 12:06:37.159 [0x70000f56f000] Debug — Request: [127.0.0.1:64345 (Loopback)] PUT /video/:/transcode/session/9772ce9f-aee9-4ee8-9982-e3b2f0fcc78d/ffa30517-df48-4ccd-9acd-735a20cd4041/progress/streamDetail?index=0&id=1&codec=h264&type=video&bitrate=4456286&profile=High&language=und&width=1280&height=720&interlaced=0&sar=1:1&level=32&frameRate=50.000&disp_default=1 (13 live) Signed-in Token (MGoeppl) (range: bytes=0-)
Aug 20, 2020 12:06:37.159 [0x70000d19d000] Debug — Completed: [127.0.0.1:64345] 200 PUT /video/:/transcode/session/9772ce9f-aee9-4ee8-9982-e3b2f0fcc78d/ffa30517-df48-4ccd-9acd-735a20cd4041/progress/streamDetail?index=0&id=1&codec=h264&type=video&bitrate=4456286&profile=High&language=und&width=1280&height=720&interlaced=0&sar=1:1&level=32&frameRate=50.000&disp_default=1 (13 live) 0ms 195 bytes (pipelined: 7) (range: bytes=0-)
Aug 20, 2020 12:06:37.159 [0x70000f56f000] Debug — Request: [127.0.0.1:64345 (Loopback)] PUT /video/:/transcode/session/9772ce9f-aee9-4ee8-9982-e3b2f0fcc78d/ffa30517-df48-4ccd-9acd-735a20cd4041/progress/streamDetail?index=1&id=2&codec=aac&type=audio&profile=LC&language=eng&channels=2&layout=stereo&sampleRate=48000&disp_default=1 (13 live) Signed-in Token (MGoeppl) (range: bytes=0-)
Aug 20, 2020 12:06:37.159 [0x70000d2a3000] Debug — Completed: [127.0.0.1:64345] 200 PUT /video/:/transcode/session/9772ce9f-aee9-4ee8-9982-e3b2f0fcc78d/ffa30517-df48-4ccd-9acd-735a20cd4041/progress/streamDetail?index=1&id=2&codec=aac&type=audio&profile=LC&language=eng&channels=2&layout=stereo&sampleRate=48000&disp_default=1 (13 live) 0ms 195 bytes (pipelined: 8) (range: bytes=0-)
Aug 20, 2020 12:06:37.160 [0x70000f56f000] Debug — Request: [127.0.0.1:64345 (Loopback)] PUT /video/:/transcode/session/9772ce9f-aee9-4ee8-9982-e3b2f0fcc78d/ffa30517-df48-4ccd-9acd-735a20cd4041/progress/streamDetail?index=2&id=3&codec=mov_text&type=subtitle&bitrate=60&language=eng&disp_default=1 (13 live) Signed-in Token (MGoeppl) (range: bytes=0-)
Aug 20, 2020 12:06:37.160 [0x70000d2a3000] Debug — Completed: [127.0.0.1:64345] 200 PUT /video/:/transcode/session/9772ce9f-aee9-4ee8-9982-e3b2f0fcc78d/ffa30517-df48-4ccd-9acd-735a20cd4041/progress/streamDetail?index=2&id=3&codec=mov_text&type=subtitle&bitrate=60&language=eng&disp_default=1 (13 live) 0ms 195 bytes (pipelined: 9) (range: bytes=0-)
Aug 20, 2020 12:06:37.161 [0x70000f56f000] Debug — Request: [127.0.0.1:64345 (Loopback)] PUT /video/:/transcode/session/9772ce9f-aee9-4ee8-9982-e3b2f0fcc78d/ffa30517-df48-4ccd-9acd-735a20cd4041/progress?duration=1736.040000 (13 live) Signed-in Token (MGoeppl) (range: bytes=0-)
Aug 20, 2020 12:06:37.161 [0x70000d11a000] Debug — Using default transcode duration of 120 minutes
Aug 20, 2020 12:06:37.161 [0x70000d2a3000] Debug — Completed: [127.0.0.1:64345] 204 PUT /video/:/transcode/session/9772ce9f-aee9-4ee8-9982-e3b2f0fcc78d/ffa30517-df48-4ccd-9acd-735a20cd4041/progress?duration=1736.040000 (13 live) 0ms 203 bytes (pipelined: 10) (range: bytes=0-)
