this is my first post and i hope this is a correct pleace thread.
I have running plexmediaserver on a Raspi 4 besides PiHole.
Now i have some trouble to update the metafiles for new added movies.
It just doesn’t work.
Then I realized this:
Thx for quick reply.
Which logs do you need? There are different ones in the Log folder.
Regarding to the update. I’m a Linux beginner so can you give me a short instruction on this?
Download the debian ARM V8 version. Put it via Filezilla in the TMP folder of the Raspi and then?
Short Update: After updating to the latest version 1.40.3.8555 it seems that the issue is solved (I hope so)
Metafiles can be updated an also Plex shows now that it is up to date.
