PLEX VS. Infuse
Server Version#:
Some of my movie Will not play in Plex on my Apple TV. It says not possible because many thing include Not enough CPU.. (see picture)
But if I go oyæut of Plex and into Infuse on my Same Apple TV witch is conneted throw Plex it the Play EVERYTHING. :thinking:
Some Apple TV, Same Connection, just two different apps??
Yes. Those apps are not associated with each other. They are coded up by different organizations, teams, and have different capabilities.
Okay.
Thank you for your awnser.
In not an PRO user, but do you Think it’s a thing PLEX could fix different so we Will nok get does Failures??
Possibly.
You’ll want to post logs so they can see more details about what the problem is and likely it’d help to share some info about the file that wasn’t playing correctly.
Instructions to get logs: https://support.plex.tv/articles/200250417-plex-media-server-log-files/
Instructions to get AppleTV Logs: https://support.plex.tv/articles/212639598-apple-tv-logs/
Media info you can just generalize (mkv vs mp4, h264\h265, AC3\DTS, bitrate) as well to get started but here are instructions to get detailed media info: https://support.plex.tv/articles/201998867-investigate-media-information-and-formats/
That’ll all be helpful for troubleshooting.
