For no apparent reason my PLEX web client (Windows 10, Google Chrome) cannot find a server.
I have uninstalled and reinstalled PLEX Server but still the problem persists.
The Server is running (used the task bar icon to update libraries) and is found by my Apple TV.
The web client only offers GENERAL settings as an option and has a ‘busy’ wheel’ going all the time as it looks for servers. There are no options on the interface to access SERVERS, only GENERAL.
Everything I’ve looked up just states that you run the web client and it will find servers.
It was working fine but now the web client and a ROKU box in the same room can’t find servers.
I had already checked both those articles. They only cover loading the Web Client in a few different ways. My problem is that the client loads, can’t find a server, and only gives limited (GENERAL) toll options. Where is the Servers tab ?
Can’t get any outside help (retired - no contacts !).
Is it a case that the IP address for my main PC (LENOVO PC) needs to start with 192.168.1.?.
If so is there an article that deals with this.
My main Apple TV connects with Plex Server and I can update the libraries from the system tray. I really miss the web client and I am super frustrated with myself for not being able to solve it. I just need a lightbulb moment.
No, the address 127.0.0.1 is not an issue. 127.0.0.1 simply means “this here computer”. It always points to the local machine. So that is irrelevant to your issue.
I took another look at your account.
The account you are using here in the forums, has no plex server in it and also no apple tv device.
This case is now pretty clear: your server and your ATV are using the same, but different plex.tv account than what your web browser is using.
I am recommending you this way, because you already have a Plex Pass on the plex account you are using with your browser.
We could go the other way, of keeping the server as it is and change the web browser instead. But then you wouldn’t have the Plex Pass benefits. Because the Plex Pass is connected to the plex account.
Thank you for bringing this to my attention!
I will tip off the relevant people to have these links repaired.
It is not an issue with server selection.
You need to get the plex client on the ATV out of the plex account it is currently using.
And subsequently into the right account.
Unfortunately, I myself don’t know the ATV client. I have never seen one, so I cannot tell you which buttons to press. Search for a ‘Settings’ dialog or something.
