Plex Web
2.10.5
NEW:
  • Add additional devices to an existing DVR
  • Character jump bar for Program Guide
  • Show progress bar for currently airing Program Guide items
  • Improved item type dropdown on Program Guide
  • Refresh available players when opening fling/cast menu
  • Remove Terms of Service/EULA from first run
  • Added ability to rescan channels after DVR setup
  • Updated translations
FIXES:
  • Fixes flinging to Plex Companion players in Chrome
  • Fixes ‘stuck’ install button when updating Windows PMS
  • Fix scrolling of device channels in Edge/IE 11
  • Fix recording button alignment on EPG
  • Better error messages from server when playback fails
  • Improved sorting of channels in DVR dialogs
  • Don’t try to Cloud Sync shared content
  • Fixes layout of photo albums when importing/adding photos
2.10.6
NEW:
  • Show next airing in Recording Priority list
FIXES:
  • Fixes editing tags in metadata
  • Fixes rendering error in subtitle renderer
  • Fixes episode artwork thumbnail when no show art exists
2.10.7
NEW:
  • (none)
FIXES:
  • Fixed broken type in add library modal
2.10.9
NEW:
  • (None)
FIXES:
  • Improved server connection handling after testing for connections
  • DVR: Remove stale channel scan in setup after cancelling one
  • DVR: Clearer device URI in DVR setup/settings
  • DVR: Remove stale DVR errors from setup
  • No longer incorrectly show rating and actions in list views
  • Clearer placeholder for XMLTV config path in Windows
2.10.10
NEW:
  • (None)
FIXES:
  • DVR: Tidy ups for manage channel dialog
  • DVR: Tidy up recording dialog
  • Don’t show navigation bar when logged out in Chrome App
2.11.0
NEW:
  • New photo player interface
  • Improved photo scaling/view to show as much photo as possible
  • Photo strip for faster photo navigation
  • Inline video playback for mixed photo/videos
  • Changed ‘Home Video’ library title to ‘Other Video’
  • In-place editing of photo title and description
  • Improved photo album view with actions and edit on photos
  • Disable unavailable remote access settings
  • DVR: Improved saving and errors for channel mapping during DVR setup
FIXES:
  • Fix unavailable error after claiming server
  • Play transcoded HLS rather than fail in Flash
  • Fix potential bad navigation from hub to library page
  • Correctly play videos in mixed photo/video libraries
  • DVR: Save channel mapping when adding device to DVR
  • DVR: Show correct month in calendar
2.12.0
NEW:
  • Extended Plex Cloud to other providers
FIXES:
  • Avatar editor now works better with small images
  • Move library toolbars to the right to give more space for titles
  • Fixed the spurious errors when saving settings
2.12.3
NEW:
  • (None)
FIXES:
  • Working on IE11 again
2.12.6
NEW:
  • Added “Advertise as player” setting to allow disabling companion
FIXES:
  • PMP: Fixed the player fullscreen button not working in Windows
  • Fixed case where playing a season would choose the wrong start episode if the on deck episode is in another season
  • Fixed image filters not being applied in the photo player when playing photos with Plex Cloud
  • Fixed cases where removing a server could lead to an infinite spinner
2.12.8
NEW:
  • Show better progress info and greater stability for library deletion and bundle cleaning
  • Show hardware decoding/encoding status on Now Playing page
  • DVR: When device channel is unmapped, show EPG channel
  • DVR: Show more detailed error messages if problems occur during setup
FIXES:
  • Fix issue that could lead to repeat playbacks in a play queue
  • Fix playback of photo channels
  • Show version count next to icon in poster
  • Improved soft subtitle support in IE and Edge
  • Improved error handling if things go bad when playing photos
  • Fixed white background from Flash
  • Cloud: Only show restart when possible
  • Cloud: Show error for users that can’t access cloud settings
  • DVR: Update devices in selector more carefully
  • DVR: Don’t show channel select for DRM protected channels
  • DVR: Program guide Starting Soon was using wrong air date
2.12.9
NEW:
  • Cloud: Show status and allow restart when fails to connect
  • Edge gets a device icon
FIXES:
  • DVR: Stop hiding dead channels so they can be disabled
  • Faster initial scroll when going back to a list
  • Ensure we load posters for partially visible items in a list
  • Fix showing durations for some channel content
  • Fix showing all path options when optimizing a hub
2.13.0
NEW:
  • Added support for webhooks
FIXED:
  • Do not allow Cloud Server to be removed from the sidebar
  • Fix Plex pass features modal scrolling in IE11
NOTE: The new interface is initially available only on the hosted Plex Web App (https://plex.tv/web). It will be included in the web app bundled with Plex Media Server in server releases in the future.
3.0.0
NEW:
  • New design for browsing library content
  • New list view with customizable, sortable columns
  • Multi-select throughout the app now behaves as it does on the dashboard
  • Filters, types, and sorts are now more easily accessed in the page header
  • Custom filters allow you to build more complex filter rules (Requires Plex Media Server version 1.4.2 or higher)
  • Added a full cast list with photos to pre-plays
  • Related lists on pre-plays allow for more discovery
  • Artwork Mode on pre-plays show off your background artwork in all its glory
  • Added support for Rotten Tomatoes and IMDb ratings
  • Added support for the Hide Seasons preference, allowing episodes to be listed directly on the show pre-play
  • Added a button to kill a stream from Now Playing
  • Increased minimum server version to 1.3.0
FIXES:
  • Fixed redirect loop in Safari Technical Preview
3.0.1
NEW:
  • Improved page contrast by slightly darkening blurred background images
  • Updated default background image to be darker and more subtle
  • Updated the style of content ratings in pre-plays and moved to the left
  • Highlight the library in the sidebar while on the pre-play
  • Increased max width of summaries in pre-plays
  • Extend summary text in the summary list view below the actions
  • Increase size of credits and streams text in pre-plays
  • Updated color of folder and music video icons next to the title in list view
  • Allow “Set up Plex Cloud…” to be hidden from server menu
FIXES:
  • Fixed issues with server events after switching users or entering a PIN
  • Fixed position of artwork in artwork mode of pre-plays
  • Fixed issue with arrow buttons in pre-play when there are more than 100 items
  • Fixed error preventing the Fix Incorrect Match modal from finding results
  • Fixed videos within photo libraries leading to an error page
  • Fixed videos within photo libraries missing actions
  • Fixed the merge action missing from shows
  • Fixed tracks in the album pre-play missing the Play Plex Mix action
  • Fixed search not prioritizing content correctly while on the library and pre-play pages
  • Fixed misaligned poster when opening the video player on pre-play while music is playing
  • Fixed issue preventing file upload dialog used for selecting account avatar from being closed in Microsoft Edge
  • Fixed issues with Webhooks settings page in Internet Explorer
3.1.1
NEW:
  • Rating and date custom filter options
FIXES:
  • Recording Priority uses correct time format setting
  • Fix link to library on the Playlist page
  • Fix link styles on Pre Plays
3.2.0
FIXES:
  • Editing photo metadata pauses slideshow
  • Fix “is” operator with title and other string custom filters
3.2.1
FIXES:
  • Fixed an error preventing photos libraries from loading for some users
3.4.0
NEW:
  • Added support for direct play of FLAC tracks in Chrome and Firefox
  • Ask for confirmation before signing out of a server on plex.tv/web
  • Add channel identifier to “Starting Soon” section of Program Guide
  • Renamed “Update Library” to “Scan Library Files”
  • Renamed “Refresh” to “Refresh Metadata”
  • Disallow closing the DVR Setup and Channel modals by clicking on the background
  • Allow managed users to change profile photo and language settings on the Account page
  • Improved wake up behavior for Plex Cloud
FIXES:
  • Only show “Import from iTunes” when creating a music library on compatible servers
  • Fixed a case causing buttons in the list toolbar to overflow on top of other content incorrectly
  • Fixed air date for Program Guide always showing US date format
  • Fixed switching DVR source during a channel scan
  • Correctly label interlaced video on the movie and episode pages
  • Fixed add to playlist with clips in a photo library using video playlists instead of photo playlists
3.4.1
FIXES:
  • Fixed “Global App Settings” being incorrectly displayed to managed users
3.5.0
NEW:
  • Added hover indicator for star ratings
  • Show server name on “Out of Date Server” page when possible
FIXES:
  • Fixed error when switching from unavailable server to an available server
  • Fixed iOS icon image paths
  • Fixed tag not being added in custom filter when apply was clicked
  • Fixed inability to select companion during local video playback
  • Fixed time format on the alerts page
