Hello All,
I have a peculiar problem that I would like sorted out. Currently I am running Plex on my Raspberry Pi. I am also running NordVpn on the Pi.
From the Plex app on my Pixel 3 XL and from one TV in my home I can access Plex while the VPN is enabled. However on the other TV I can not access Plex.
The Pixel 3 XL is on my wifi network, the Pi and both TVs are plugged into a switch connected to my modem.
The TV that can access Plex is directly wired to the switch, where are the TV that can not access Plex is wired TV to Google Mesh Wifi Pod to Switch to Modem.
I have been going over settings and I do believe they are correct. Each TV is allowed to fall back to an insecure connection on the same network. I believe the only difference between the two TVs (both Samsung Qseries) is the wiring back to the modem. I can not change the wiring of the one TV that can not access Plex. I am however curious to know if anyone else has ever had this problem, if they solved it, or if anyone has ideas.
