Latest Beta (September 23rd) did not fix this issue. Any updates on when we can expect a fix ?
Still no luck with the last released version 1.20.2.3402.
Would like to see server logs of the problems scanning channels when using the current beta of Plex Media Server - 1.20.3.3421-54b6523bd
That release has changes for dvb-c
Is the issue being seen just for dvb-c ? or dvb-t as well?
Please let me have model and type of DVR and logs captured after a failed scan. Please reproduce the problem after ensuring debug logging is enabled and restarting the server
Just installed the latest PMS veresion and Iām now able to select the network ID and start scanning (DVB-C DualHD Netherlands). All channels found however now I was stuck on the next page where it asks for my location for an electronic guide. Could not press continue after selecting my language (wonāt ask me for region). Same for all countries/languages. Is there no out of the box EPG support?
Anyhow, after manually selecting an XMLTV file I can continue but would be nice if I can just watch without the whole EPG stuff and watch live channels.
I am also running into this issue. I should have checked before I deleted my tuners(I couldnāt get it to tune to any channel) sigh! It used to pickup the guide just fine.
Edit: Found the solution! Use the windows plex app and it works perfectly
If the country is not supported for EPG then xmltv needs to be used
See this page for list of supported countries
https://support.plex.tv/articles/226463767-frequently-asked-questions-dvr-live-tv/
This will change when we switch providers - see
If you have an issue where there is no EPG for a supported country - please provide screenshots and Plex Media Server debug logs
See
https://support.plex.tv/articles/201643703-reporting-issues-with-plex-media-server/
https://support.plex.tv/articles/200250417-plex-media-server-log-files/
I have the same model, Hauppauge 1213 WinTV-HVR-2255, And it is not found on plex, have had this issue since buying the card on January 24, 2016. Never found solution to it. Anyone have any ideas, or know how to get it working? i am using windows 10, with latest PMS ( 1.21.1.3830) I would greatly appreciate any input or ideas
Hi @sa2000,
Regarding this topic, with the WinTV-DualHD on my Windows machine everything worked just fine after the updates we previously mentioned in this topic. Do you by any chance have any information if the fix was specifically for Windows machines or also for Linux distroās in general? Currently facing the same issue on my Linux box. Other than DVR everything works perfectly but the tune fails again pretty much directly in the initial stage (jumps to 50% and than fails directly). Exactly the same issue we saw before with the previous versions.
Arch Linux (kernel 5.10.9)
PMS 1.21.1.3876
Hauppauge WinTV-DualHD
Netherlands, DVB-C @ 316Mhz (Caiway)
Once again I would very much appreciate your help and make this great project a full 100% again on all my devices
Jan 23, 2021 01:21:09.463 [0x7f12837fe640] INFO - [I] web_service_t::process_scan_request
Jan 23, 2021 01:21:09.464 [0x7f12837fe640] INFO - [I] device_reactor_t::get_device_list (dvb#v4l#/sys/devices/pci0000:00/0000:00:14.0/usb3/3-9/3-9:1.0:0014135745)
Jan 23, 2021 01:21:09.464 [0x7f12837fe640] INFO - [I] dvb_device_factory_t::get_device_list (dvb#v4l#/sys/devices/pci0000:00/0000:00:14.0/usb3/3-9/3-9:1.0:0014135745)
Jan 23, 2021 01:21:09.464 [0x7f12837fe640] INFO - [I] v4l::DeviceGetList_impl. getting v4l device list
Jan 23, 2021 01:21:09.464 [0x7f12837fe640] INFO - [I] v4l::DeviceGetList_impl. Successfully opened frontend /dev/dvb/adapter0/frontend0
Jan 23, 2021 01:21:09.465 [0x7f12837fe640] INFO - [I] v4l::DeviceGetList_impl. Successfully opened frontend /dev/dvb/adapter1/frontend0
Jan 23, 2021 01:21:09.469 [0x7f12837fe640] INFO - [I] dvb_device_factory_t::get_device_list. Id dvb#v4l#0#/sys/devices/pci0000:00/0000:00:14.0/usb3/3-9/3-9:1.0:0, Name dualHD, Standards 3
Jan 23, 2021 01:21:09.469 [0x7f12837fe640] INFO - [I] dvb_device_factory_t::get_device_list. Id dvb#v4l#0#/sys/devices/pci0000:00/0000:00:14.0/usb3/3-9/3-9:1.0:1, Name dualHD, Standards 3
Jan 23, 2021 01:21:09.469 [0x7f12837fe640] INFO - [I] device_manager_t::get_device_list. Device dualHD, id dvb#v4l#0#/sys/devices/pci0000:00/0000:00:14.0/usb3/3-9/3-9:1.0:0, tuners 1, state 4, standards 3
Jan 23, 2021 01:21:09.469 [0x7f12837fe640] INFO - [I] device_manager_t::get_device_list. Device dualHD, id dvb#v4l#0#/sys/devices/pci0000:00/0000:00:14.0/usb3/3-9/3-9:1.0:1, tuners 1, state 5, standards 3
Jan 23, 2021 01:21:09.469 [0x7f12837fe640] INFO - [I] device_manager_t::scan_start. Device dvb#v4l#0#/sys/devices/pci0000:00/0000:00:14.0/usb3/3-9/3-9:1.0:0
Jan 23, 2021 01:21:09.469 [0x7f125bfff640] INFO - [I] channel_scanner_t::scan_thread_function started
Jan 23, 2021 01:21:09.469 [0x7f125bfff640] INFO - [I] channel_scanner_t::scan_thread_function. Scanning networks
Jan 23, 2021 01:21:09.470 [0x7f1289218640] INFO - [I] web_service_t::process_device_status
Jan 23, 2021 01:21:09.470 [0x7f1289218640] INFO - [I] device_reactor_t::get_device_list (dvb#v4l#/sys/devices/pci0000:00/0000:00:14.0/usb3/3-9/3-9:1.0:0014135745)
Jan 23, 2021 01:21:09.470 [0x7f1289218640] INFO - [I] dvb_device_factory_t::get_device_list (dvb#v4l#/sys/devices/pci0000:00/0000:00:14.0/usb3/3-9/3-9:1.0:0014135745)
Jan 23, 2021 01:21:09.470 [0x7f1289218640] INFO - [I] v4l::DeviceGetList_impl. getting v4l device list
Jan 23, 2021 01:21:09.470 [0x7f1289218640] INFO - [I] v4l::DeviceGetList_impl. Successfully opened frontend /dev/dvb/adapter0/frontend0
Jan 23, 2021 01:21:09.470 [0x7f1289218640] INFO - [I] v4l::DeviceGetList_impl. Successfully opened frontend /dev/dvb/adapter1/frontend0
Jan 23, 2021 01:21:09.472 [0x7f1289218640] INFO - [I] dvb_device_factory_t::get_device_list. Id dvb#v4l#0#/sys/devices/pci0000:00/0000:00:14.0/usb3/3-9/3-9:1.0:0, Name dualHD, Standards 3
Jan 23, 2021 01:21:09.472 [0x7f1289218640] INFO - [I] dvb_device_factory_t::get_device_list. Id dvb#v4l#0#/sys/devices/pci0000:00/0000:00:14.0/usb3/3-9/3-9:1.0:1, Name dualHD, Standards 3
Jan 23, 2021 01:21:09.472 [0x7f1289218640] INFO - [I] device_manager_t::get_device_list. Device dualHD, id dvb#v4l#0#/sys/devices/pci0000:00/0000:00:14.0/usb3/3-9/3-9:1.0:0, tuners 1, state 3, standards 3
Jan 23, 2021 01:21:09.472 [0x7f1289218640] INFO - [I] device_manager_t::get_device_list. Device dualHD, id dvb#v4l#0#/sys/devices/pci0000:00/0000:00:14.0/usb3/3-9/3-9:1.0:1, tuners 1, state 5, standards 3
Jan 23, 2021 01:21:09.472 [0x7f1288a17640] INFO - [I] web_service_t::process_device_status
Jan 23, 2021 01:21:09.472 [0x7f1288a17640] INFO - [I] device_reactor_t::get_device_list (dvb#v4l#/sys/devices/pci0000:00/0000:00:14.0/usb3/3-9/3-9:1.0:0014135745)
Jan 23, 2021 01:21:09.472 [0x7f1288a17640] INFO - [I] dvb_device_factory_t::get_device_list (dvb#v4l#/sys/devices/pci0000:00/0000:00:14.0/usb3/3-9/3-9:1.0:0014135745)
Jan 23, 2021 01:21:09.472 [0x7f1288a17640] INFO - [I] v4l::DeviceGetList_impl. getting v4l device list
Jan 23, 2021 01:21:09.472 [0x7f1288a17640] INFO - [I] v4l::DeviceGetList_impl. Successfully opened frontend /dev/dvb/adapter0/frontend0
Jan 23, 2021 01:21:09.473 [0x7f1288a17640] INFO - [I] v4l::DeviceGetList_impl. Successfully opened frontend /dev/dvb/adapter1/frontend0
Jan 23, 2021 01:21:09.474 [0x7f1288a17640] INFO - [I] dvb_device_factory_t::get_device_list. Id dvb#v4l#0#/sys/devices/pci0000:00/0000:00:14.0/usb3/3-9/3-9:1.0:0, Name dualHD, Standards 3
Jan 23, 2021 01:21:09.474 [0x7f1288a17640] INFO - [I] dvb_device_factory_t::get_device_list. Id dvb#v4l#0#/sys/devices/pci0000:00/0000:00:14.0/usb3/3-9/3-9:1.0:1, Name dualHD, Standards 3
Jan 23, 2021 01:21:09.474 [0x7f1288a17640] INFO - [I] device_manager_t::get_device_list. Device dualHD, id dvb#v4l#0#/sys/devices/pci0000:00/0000:00:14.0/usb3/3-9/3-9:1.0:0, tuners 1, state 3, standards 3
Jan 23, 2021 01:21:09.474 [0x7f1288a17640] INFO - [I] device_manager_t::get_device_list. Device dualHD, id dvb#v4l#0#/sys/devices/pci0000:00/0000:00:14.0/usb3/3-9/3-9:1.0:1, tuners 1, state 5, standards 3
Jan 23, 2021 01:21:09.475 [0x7f1282ffd640] INFO - [I] web_service_t::process_get_scanners
Jan 23, 2021 01:21:09.475 [0x7f1282ffd640] INFO - [I] device_reactor_t::get_device_list (dvb#v4l#/sys/devices/pci0000:00/0000:00:14.0/usb3/3-9/3-9:1.0:0014135745)
Jan 23, 2021 01:21:09.475 [0x7f1282ffd640] INFO - [I] dvb_device_factory_t::get_device_list (dvb#v4l#/sys/devices/pci0000:00/0000:00:14.0/usb3/3-9/3-9:1.0:0014135745)
Jan 23, 2021 01:21:09.475 [0x7f1282ffd640] INFO - [I] v4l::DeviceGetList_impl. getting v4l device list
Jan 23, 2021 01:21:09.475 [0x7f1282ffd640] INFO - [I] v4l::DeviceGetList_impl. Successfully opened frontend /dev/dvb/adapter0/frontend0
Jan 23, 2021 01:21:09.475 [0x7f1282ffd640] INFO - [I] v4l::DeviceGetList_impl. Successfully opened frontend /dev/dvb/adapter1/frontend0
Jan 23, 2021 01:21:09.477 [0x7f1282ffd640] INFO - [I] dvb_device_factory_t::get_device_list. Id dvb#v4l#0#/sys/devices/pci0000:00/0000:00:14.0/usb3/3-9/3-9:1.0:0, Name dualHD, Standards 3
Jan 23, 2021 01:21:09.477 [0x7f1282ffd640] INFO - [I] dvb_device_factory_t::get_device_list. Id dvb#v4l#0#/sys/devices/pci0000:00/0000:00:14.0/usb3/3-9/3-9:1.0:1, Name dualHD, Standards 3
Jan 23, 2021 01:21:09.477 [0x7f1282ffd640] INFO - [I] device_manager_t::get_device_list. Device dualHD, id dvb#v4l#0#/sys/devices/pci0000:00/0000:00:14.0/usb3/3-9/3-9:1.0:0, tuners 1, state 3, standards 3
Jan 23, 2021 01:21:09.477 [0x7f1282ffd640] INFO - [I] device_manager_t::get_device_list. Device dualHD, id dvb#v4l#0#/sys/devices/pci0000:00/0000:00:14.0/usb3/3-9/3-9:1.0:1, tuners 1, state 5, standards 3
Jan 23, 2021 01:21:09.519 [0x7f125affd640] INFO - [I] find_device_by_path. searching for matching tuner with device path /sys/devices/pci0000:00/0000:00:14.0/usb3/3-9/3-9:1.0:0
Jan 23, 2021 01:21:09.520 [0x7f125affd640] INFO - [I] v4l::DeviceGetList_impl. getting v4l device list
Jan 23, 2021 01:21:09.520 [0x7f125affd640] INFO - [I] v4l::DeviceGetList_impl. Successfully opened frontend /dev/dvb/adapter0/frontend0
Jan 23, 2021 01:21:09.520 [0x7f125affd640] INFO - [I] v4l::DeviceGetList_impl. Successfully opened frontend /dev/dvb/adapter1/frontend0
Jan 23, 2021 01:21:09.522 [0x7f125affd640] INFO - [I] find_device_by_path. Found device index 0 for device path /sys/devices/pci0000:00/0000:00:14.0/usb3/3-9/3-9:1.0:0
Jan 23, 2021 01:21:09.522 [0x7f125affd640] INFO - [I] Starting tuner 0, frontend 0
Jan 23, 2021 01:21:09.552 [0x7f125affd640] INFO - [I] tuner 0, frontend 0 was opened successfully
Jan 23, 2021 01:21:09.552 [0x7f125affd640] INFO - [I] detected tuner ids: vendor (2040), product (8265)
Jan 23, 2021 01:21:09.552 [0x7f125affd640] INFO - [I] No ca0 node is present for tuner 0
Jan 23, 2021 01:21:09.552 [0x7f125affd640] INFO - [I] CTVSStreamSource::TuneTransponder. Transponder tuning request: diseqc 0, freq 316000, modulation 0, polarization 0, symbol rate 6900000, LOF 5, LNB selection signal 0, FEC 0
Jan 23, 2021 01:21:09.552 [0x7f125affd640] INFO - [I] Tuning request. 316000, 5, 6900000, 0, 0, 0, 0
Jan 23, 2021 01:21:09.562 [0x7f125affd640] WARN - [W] CV4lTunersStreamSrc::Start. pthread_setschedparam failed 1
Jan 23, 2021 01:21:09.562 [0x7f1259ffb640] INFO - [I] Starting streaming thread for tuner 0, frontend 0
Jan 23, 2021 01:21:09.563 [0x7f1259ffb640] INFO - [I] tuner 0, demux 0. adding PID 20
Jan 23, 2021 01:21:12.490 [0x7f12827fc640] INFO - [I] web_service_t::process_device_status
Jan 23, 2021 01:21:12.490 [0x7f12827fc640] INFO - [I] device_reactor_t::get_device_list (dvb#v4l#/sys/devices/pci0000:00/0000:00:14.0/usb3/3-9/3-9:1.0:0014135745)
Jan 23, 2021 01:21:12.490 [0x7f12827fc640] INFO - [I] dvb_device_factory_t::get_device_list (dvb#v4l#/sys/devices/pci0000:00/0000:00:14.0/usb3/3-9/3-9:1.0:0014135745)
Jan 23, 2021 01:21:12.490 [0x7f12827fc640] INFO - [I] v4l::DeviceGetList_impl. getting v4l device list
Jan 23, 2021 01:21:12.490 [0x7f12827fc640] INFO - [I] v4l::DeviceGetList_impl. Successfully opened frontend /dev/dvb/adapter0/frontend0
Jan 23, 2021 01:21:12.490 [0x7f12827fc640] INFO - [I] v4l::DeviceGetList_impl. Successfully opened frontend /dev/dvb/adapter1/frontend0
Jan 23, 2021 01:21:12.496 [0x7f12827fc640] INFO - [I] dvb_device_factory_t::get_device_list. Id dvb#v4l#0#/sys/devices/pci0000:00/0000:00:14.0/usb3/3-9/3-9:1.0:0, Name dualHD, Standards 3
Jan 23, 2021 01:21:12.496 [0x7f12827fc640] INFO - [I] dvb_device_factory_t::get_device_list. Id dvb#v4l#0#/sys/devices/pci0000:00/0000:00:14.0/usb3/3-9/3-9:1.0:1, Name dualHD, Standards 3
Jan 23, 2021 01:21:12.496 [0x7f12827fc640] INFO - [I] device_manager_t::get_device_list. Device dualHD, id dvb#v4l#0#/sys/devices/pci0000:00/0000:00:14.0/usb3/3-9/3-9:1.0:0, tuners 1, state 3, standards 3
Jan 23, 2021 01:21:12.496 [0x7f12827fc640] INFO - [I] device_manager_t::get_device_list. Device dualHD, id dvb#v4l#0#/sys/devices/pci0000:00/0000:00:14.0/usb3/3-9/3-9:1.0:1, tuners 1, state 5, standards 3
Jan 23, 2021 01:21:12.498 [0x7f1289218640] INFO - [I] web_service_t::process_device_status
Jan 23, 2021 01:21:12.498 [0x7f1289218640] INFO - [I] device_reactor_t::get_device_list (dvb#v4l#/sys/devices/pci0000:00/0000:00:14.0/usb3/3-9/3-9:1.0:0014135745)
Jan 23, 2021 01:21:12.498 [0x7f1289218640] INFO - [I] dvb_device_factory_t::get_device_list (dvb#v4l#/sys/devices/pci0000:00/0000:00:14.0/usb3/3-9/3-9:1.0:0014135745)
Jan 23, 2021 01:21:12.498 [0x7f1289218640] INFO - [I] v4l::DeviceGetList_impl. getting v4l device list
Jan 23, 2021 01:21:12.499 [0x7f1289218640] INFO - [I] v4l::DeviceGetList_impl. Successfully opened frontend /dev/dvb/adapter0/frontend0
Jan 23, 2021 01:21:12.499 [0x7f1289218640] INFO - [I] v4l::DeviceGetList_impl. Successfully opened frontend /dev/dvb/adapter1/frontend0
Jan 23, 2021 01:21:12.504 [0x7f1289218640] INFO - [I] dvb_device_factory_t::get_device_list. Id dvb#v4l#0#/sys/devices/pci0000:00/0000:00:14.0/usb3/3-9/3-9:1.0:0, Name dualHD, Standards 3
Jan 23, 2021 01:21:12.504 [0x7f1289218640] INFO - [I] dvb_device_factory_t::get_device_list. Id dvb#v4l#0#/sys/devices/pci0000:00/0000:00:14.0/usb3/3-9/3-9:1.0:1, Name dualHD, Standards 3
Jan 23, 2021 01:21:12.504 [0x7f1289218640] INFO - [I] device_manager_t::get_device_list. Device dualHD, id dvb#v4l#0#/sys/devices/pci0000:00/0000:00:14.0/usb3/3-9/3-9:1.0:0, tuners 1, state 3, standards 3
Jan 23, 2021 01:21:12.504 [0x7f1289218640] INFO - [I] device_manager_t::get_device_list. Device dualHD, id dvb#v4l#0#/sys/devices/pci0000:00/0000:00:14.0/usb3/3-9/3-9:1.0:1, tuners 1, state 5, standards 3
Jan 23, 2021 01:21:12.505 [0x7f12837fe640] INFO - [I] web_service_t::process_get_scanners
Jan 23, 2021 01:21:12.505 [0x7f12837fe640] INFO - [I] device_reactor_t::get_device_list (dvb#v4l#/sys/devices/pci0000:00/0000:00:14.0/usb3/3-9/3-9:1.0:0014135745)
Jan 23, 2021 01:21:12.505 [0x7f12837fe640] INFO - [I] dvb_device_factory_t::get_device_list (dvb#v4l#/sys/devices/pci0000:00/0000:00:14.0/usb3/3-9/3-9:1.0:0014135745)
Jan 23, 2021 01:21:12.505 [0x7f12837fe640] INFO - [I] v4l::DeviceGetList_impl. getting v4l device list
Jan 23, 2021 01:21:12.505 [0x7f12837fe640] INFO - [I] v4l::DeviceGetList_impl. Successfully opened frontend /dev/dvb/adapter0/frontend0
Jan 23, 2021 01:21:12.505 [0x7f12837fe640] INFO - [I] v4l::DeviceGetList_impl. Successfully opened frontend /dev/dvb/adapter1/frontend0
Jan 23, 2021 01:21:12.507 [0x7f12837fe640] INFO - [I] dvb_device_factory_t::get_device_list. Id dvb#v4l#0#/sys/devices/pci0000:00/0000:00:14.0/usb3/3-9/3-9:1.0:0, Name dualHD, Standards 3
Jan 23, 2021 01:21:12.507 [0x7f12837fe640] INFO - [I] dvb_device_factory_t::get_device_list. Id dvb#v4l#0#/sys/devices/pci0000:00/0000:00:14.0/usb3/3-9/3-9:1.0:1, Name dualHD, Standards 3
Jan 23, 2021 01:21:12.507 [0x7f12837fe640] INFO - [I] device_manager_t::get_device_list. Device dualHD, id dvb#v4l#0#/sys/devices/pci0000:00/0000:00:14.0/usb3/3-9/3-9:1.0:0, tuners 1, state 3, standards 3
Jan 23, 2021 01:21:12.507 [0x7f12837fe640] INFO - [I] device_manager_t::get_device_list. Device dualHD, id dvb#v4l#0#/sys/devices/pci0000:00/0000:00:14.0/usb3/3-9/3-9:1.0:1, tuners 1, state 5, standards 3
Jan 23, 2021 01:21:14.626 [0x7f125bfff640] INFO - [I] CTVSChannelScanner::Tune. Wait for lock timeout
Jan 23, 2021 01:21:14.626 [0x7f125bfff640] WARN - [E] dvb_channel_scanner_t::scan_networks. Tune failed for 316000,V,6900,,QAM64
Jan 23, 2021 01:21:14.626 [0x7f125bfff640] WARN - [E] channel_scanner_t::scan_thread_function. Network scan failed
Jan 23, 2021 01:21:14.626 [0x7f125bfff640] INFO - [I] CTVSStreamSource::Term. Waiting for streaming thread to stop
Jan 23, 2021 01:21:14.676 [0x7f125affd640] INFO - [I] Stop device request for tuner 0, frontend 0
Jan 23, 2021 01:21:14.681 [0x7f1259ffb640] INFO - [I] Exiting streaming thread for tuner 0, frontend 0
Jan 23, 2021 01:21:14.682 [0x7f125bfff640] INFO - [I] CTVSStreamSource::Term. Streaming is stopped
Jan 23, 2021 01:21:14.682 [0x7f125bfff640] INFO - [I] CTVSStreamSource::Term. Stream source is stopped
Jan 23, 2021 01:21:14.682 [0x7f125bfff640] INFO - [I] channel_scanner_t::scan_thread_function finished
Jan 23, 2021 01:21:15.518 [0x7f1283fff640] INFO - [I] web_service_t::process_device_status
Jan 23, 2021 01:21:15.518 [0x7f1283fff640] INFO - [I] device_reactor_t::get_device_list (dvb#v4l#/sys/devices/pci0000:00/0000:00:14.0/usb3/3-9/3-9:1.0:0014135745)
Jan 23, 2021 01:21:15.518 [0x7f1283fff640] INFO - [I] dvb_device_factory_t::get_device_list (dvb#v4l#/sys/devices/pci0000:00/0000:00:14.0/usb3/3-9/3-9:1.0:0014135745)
Jan 23, 2021 01:21:15.518 [0x7f1283fff640] INFO - [I] v4l::DeviceGetList_impl. getting v4l device list
Jan 23, 2021 01:21:15.518 [0x7f1283fff640] INFO - [I] v4l::DeviceGetList_impl. Successfully opened frontend /dev/dvb/adapter0/frontend0
Jan 23, 2021 01:21:15.519 [0x7f1283fff640] INFO - [I] v4l::DeviceGetList_impl. Successfully opened frontend /dev/dvb/adapter1/frontend0
Jan 23, 2021 01:21:15.524 [0x7f1283fff640] INFO - [I] dvb_device_factory_t::get_device_list. Id dvb#v4l#0#/sys/devices/pci0000:00/0000:00:14.0/usb3/3-9/3-9:1.0:0, Name dualHD, Standards 3
Jan 23, 2021 01:21:15.524 [0x7f1283fff640] INFO - [I] dvb_device_factory_t::get_device_list. Id dvb#v4l#0#/sys/devices/pci0000:00/0000:00:14.0/usb3/3-9/3-9:1.0:1, Name dualHD, Standards 3
Jan 23, 2021 01:21:15.524 [0x7f1283fff640] INFO - [I] device_manager_t::get_device_list. Device dualHD, id dvb#v4l#0#/sys/devices/pci0000:00/0000:00:14.0/usb3/3-9/3-9:1.0:0, tuners 1, state 4, standards 3
Jan 23, 2021 01:21:15.524 [0x7f1283fff640] INFO - [I] device_manager_t::get_device_list. Device dualHD, id dvb#v4l#0#/sys/devices/pci0000:00/0000:00:14.0/usb3/3-9/3-9:1.0:1, tuners 1, state 5, standards 3
Jan 23, 2021 01:21:15.526 [0x7f1282ffd640] INFO - [I] web_service_t::process_get_networks
Jan 23, 2021 01:21:15.526 [0x7f1282ffd640] INFO - [I] device_reactor_t::get_device_list (dvb#v4l#/sys/devices/pci0000:00/0000:00:14.0/usb3/3-9/3-9:1.0:0014135745)
Jan 23, 2021 01:21:15.526 [0x7f1282ffd640] INFO - [I] dvb_device_factory_t::get_device_list (dvb#v4l#/sys/devices/pci0000:00/0000:00:14.0/usb3/3-9/3-9:1.0:0014135745)
Jan 23, 2021 01:21:15.527 [0x7f1282ffd640] INFO - [I] v4l::DeviceGetList_impl. getting v4l device list
Jan 23, 2021 01:21:15.527 [0x7f1282ffd640] INFO - [I] v4l::DeviceGetList_impl. Successfully opened frontend /dev/dvb/adapter0/frontend0
Jan 23, 2021 01:21:15.527 [0x7f1282ffd640] INFO - [I] v4l::DeviceGetList_impl. Successfully opened frontend /dev/dvb/adapter1/frontend0
Jan 23, 2021 01:21:15.532 [0x7f1282ffd640] INFO - [I] dvb_device_factory_t::get_device_list. Id dvb#v4l#0#/sys/devices/pci0000:00/0000:00:14.0/usb3/3-9/3-9:1.0:0, Name dualHD, Standards 3
Jan 23, 2021 01:21:15.532 [0x7f1282ffd640] INFO - [I] dvb_device_factory_t::get_device_list. Id dvb#v4l#0#/sys/devices/pci0000:00/0000:00:14.0/usb3/3-9/3-9:1.0:1, Name dualHD, Standards 3
Jan 23, 2021 01:21:15.532 [0x7f1282ffd640] INFO - [I] device_manager_t::get_device_list. Device dualHD, id dvb#v4l#0#/sys/devices/pci0000:00/0000:00:14.0/usb3/3-9/3-9:1.0:0, tuners 1, state 4, standards 3
Jan 23, 2021 01:21:15.532 [0x7f1282ffd640] INFO - [I] device_manager_t::get_device_list. Device dualHD, id dvb#v4l#0#/sys/devices/pci0000:00/0000:00:14.0/usb3/3-9/3-9:1.0:1, tuners 1, state 5, standards 3
Jan 23, 2021 01:21:15.532 [0x7f1282ffd640] INFO - [I] device_manager_t::scan_get_networks. Device dvb#v4l#0#/sys/devices/pci0000:00/0000:00:14.0/usb3/3-9/3-9:1.0:0
Jan 23, 2021 01:21:15.532 [0x7f1281ffb640] INFO - [I] web_service_t::process_device_status
Jan 23, 2021 01:21:15.532 [0x7f1281ffb640] INFO - [I] device_reactor_t::get_device_list (dvb#v4l#/sys/devices/pci0000:00/0000:00:14.0/usb3/3-9/3-9:1.0:0014135745)
Jan 23, 2021 01:21:15.532 [0x7f1281ffb640] INFO - [I] dvb_device_factory_t::get_device_list (dvb#v4l#/sys/devices/pci0000:00/0000:00:14.0/usb3/3-9/3-9:1.0:0014135745)
Jan 23, 2021 01:21:15.532 [0x7f1281ffb640] INFO - [I] v4l::DeviceGetList_impl. getting v4l device list
Jan 23, 2021 01:21:15.532 [0x7f1281ffb640] INFO - [I] v4l::DeviceGetList_impl. Successfully opened frontend /dev/dvb/adapter0/frontend0
Jan 23, 2021 01:21:15.533 [0x7f1281ffb640] INFO - [I] v4l::DeviceGetList_impl. Successfully opened frontend /dev/dvb/adapter1/frontend0
Jan 23, 2021 01:21:15.534 [0x7f1281ffb640] INFO - [I] dvb_device_factory_t::get_device_list. Id dvb#v4l#0#/sys/devices/pci0000:00/0000:00:14.0/usb3/3-9/3-9:1.0:0, Name dualHD, Standards 3
Jan 23, 2021 01:21:15.534 [0x7f1281ffb640] INFO - [I] dvb_device_factory_t::get_device_list. Id dvb#v4l#0#/sys/devices/pci0000:00/0000:00:14.0/usb3/3-9/3-9:1.0:1, Name dualHD, Standards 3
Jan 23, 2021 01:21:15.534 [0x7f1281ffb640] INFO - [I] device_manager_t::get_device_list. Device dualHD, id dvb#v4l#0#/sys/devices/pci0000:00/0000:00:14.0/usb3/3-9/3-9:1.0:0, tuners 1, state 4, standards 3
Jan 23, 2021 01:21:15.534 [0x7f1281ffb640] INFO - [I] device_manager_t::get_device_list. Device dualHD, id dvb#v4l#0#/sys/devices/pci0000:00/0000:00:14.0/usb3/3-9/3-9:1.0:1, tuners 1, state 5, standards 3
Jan 23, 2021 01:21:15.535 [0x7f1288a17640] INFO - [I] web_service_t::process_get_networks
Jan 23, 2021 01:21:15.535 [0x7f1288a17640] INFO - [I] device_reactor_t::get_device_list (dvb#v4l#/sys/devices/pci0000:00/0000:00:14.0/usb3/3-9/3-9:1.0:0014135745)
Jan 23, 2021 01:21:15.535 [0x7f1288a17640] INFO - [I] dvb_device_factory_t::get_device_list (dvb#v4l#/sys/devices/pci0000:00/0000:00:14.0/usb3/3-9/3-9:1.0:0014135745)
Jan 23, 2021 01:21:15.535 [0x7f1288a17640] INFO - [I] v4l::DeviceGetList_impl. getting v4l device list
Jan 23, 2021 01:21:15.535 [0x7f1288a17640] INFO - [I] v4l::DeviceGetList_impl. Successfully opened frontend /dev/dvb/adapter0/frontend0
Jan 23, 2021 01:21:15.536 [0x7f1288a17640] INFO - [I] v4l::DeviceGetList_impl. Successfully opened frontend /dev/dvb/adapter1/frontend0
Jan 23, 2021 01:21:15.541 [0x7f1288a17640] INFO - [I] dvb_device_factory_t::get_device_list. Id dvb#v4l#0#/sys/devices/pci0000:00/0000:00:14.0/usb3/3-9/3-9:1.0:0, Name dualHD, Standards 3
Jan 23, 2021 01:21:15.541 [0x7f1288a17640] INFO - [I] dvb_device_factory_t::get_device_list. Id dvb#v4l#0#/sys/devices/pci0000:00/0000:00:14.0/usb3/3-9/3-9:1.0:1, Name dualHD, Standards 3
Jan 23, 2021 01:21:15.541 [0x7f1288a17640] INFO - [I] device_manager_t::get_device_list. Device dualHD, id dvb#v4l#0#/sys/devices/pci0000:00/0000:00:14.0/usb3/3-9/3-9:1.0:0, tuners 1, state 4, standards 3
Jan 23, 2021 01:21:15.541 [0x7f1288a17640] INFO - [I] device_manager_t::get_device_list. Device dualHD, id dvb#v4l#0#/sys/devices/pci0000:00/0000:00:14.0/usb3/3-9/3-9:1.0:1, tuners 1, state 5, standards 3
Jan 23, 2021 01:21:15.541 [0x7f1288a17640] INFO - [I] device_manager_t::scan_get_networks. Device dvb#v4l#0#/sys/devices/pci0000:00/0000:00:14.0/usb3/3-9/3-9:1.0:0
Jan 23, 2021 01:21:15.542 [0x7f1289a19640] INFO - [I] web_service_t::process_get_scanners
Jan 23, 2021 01:21:15.542 [0x7f1289a19640] INFO - [I] device_reactor_t::get_device_list (dvb#v4l#/sys/devices/pci0000:00/0000:00:14.0/usb3/3-9/3-9:1.0:0014135745)
Jan 23, 2021 01:21:15.542 [0x7f1289a19640] INFO - [I] dvb_device_factory_t::get_device_list (dvb#v4l#/sys/devices/pci0000:00/0000:00:14.0/usb3/3-9/3-9:1.0:0014135745)
Jan 23, 2021 01:21:15.542 [0x7f1289a19640] INFO - [I] v4l::DeviceGetList_impl. getting v4l device list
Jan 23, 2021 01:21:15.542 [0x7f1289a19640] INFO - [I] v4l::DeviceGetList_impl. Successfully opened frontend /dev/dvb/adapter0/frontend0
Jan 23, 2021 01:21:15.542 [0x7f1289a19640] INFO - [I] v4l::DeviceGetList_impl. Successfully opened frontend /dev/dvb/adapter1/frontend0
Jan 23, 2021 01:21:15.544 [0x7f1289a19640] INFO - [I] dvb_device_factory_t::get_device_list. Id dvb#v4l#0#/sys/devices/pci0000:00/0000:00:14.0/usb3/3-9/3-9:1.0:0, Name dualHD, Standards 3
Jan 23, 2021 01:21:15.544 [0x7f1289a19640] INFO - [I] dvb_device_factory_t::get_device_list. Id dvb#v4l#0#/sys/devices/pci0000:00/0000:00:14.0/usb3/3-9/3-9:1.0:1, Name dualHD, Standards 3
Jan 23, 2021 01:21:15.544 [0x7f1289a19640] INFO - [I] device_manager_t::get_device_list. Device dualHD, id dvb#v4l#0#/sys/devices/pci0000:00/0000:00:14.0/usb3/3-9/3-9:1.0:0, tuners 1, state 4, standards 3
Jan 23, 2021 01:21:15.544 [0x7f1289a19640] INFO - [I] device_manager_t::get_device_list. Device dualHD, id dvb#v4l#0#/sys/devices/pci0000:00/0000:00:14.0/usb3/3-9/3-9:1.0:1, tuners 1, state 5, standards 3
Jan 23, 2021 01:21:15.553 [0x7f1289218640] INFO - [I] web_service_t::process_get_channels
Jan 23, 2021 01:21:15.553 [0x7f1289218640] INFO - [I] device_reactor_t::get_device_list (dvb#v4l#/sys/devices/pci0000:00/0000:00:14.0/usb3/3-9/3-9:1.0:0014135745)
Jan 23, 2021 01:21:15.553 [0x7f1289218640] INFO - [I] dvb_device_factory_t::get_device_list (dvb#v4l#/sys/devices/pci0000:00/0000:00:14.0/usb3/3-9/3-9:1.0:0014135745)
Jan 23, 2021 01:21:15.553 [0x7f1289218640] INFO - [I] v4l::DeviceGetList_impl. getting v4l device list
Jan 23, 2021 01:21:15.553 [0x7f1289218640] INFO - [I] v4l::DeviceGetList_impl. Successfully opened frontend /dev/dvb/adapter0/frontend0
Jan 23, 2021 01:21:15.553 [0x7f1289218640] INFO - [I] v4l::DeviceGetList_impl. Successfully opened frontend /dev/dvb/adapter1/frontend0
Jan 23, 2021 01:21:15.555 [0x7f1289218640] INFO - [I] dvb_device_factory_t::get_device_list. Id dvb#v4l#0#/sys/devices/pci0000:00/0000:00:14.0/usb3/3-9/3-9:1.0:0, Name dualHD, Standards 3
Jan 23, 2021 01:21:15.555 [0x7f1289218640] INFO - [I] dvb_device_factory_t::get_device_list. Id dvb#v4l#0#/sys/devices/pci0000:00/0000:00:14.0/usb3/3-9/3-9:1.0:1, Name dualHD, Standards 3
Jan 23, 2021 01:21:15.555 [0x7f1289218640] INFO - [I] device_manager_t::get_device_list. Device dualHD, id dvb#v4l#0#/sys/devices/pci0000:00/0000:00:14.0/usb3/3-9/3-9:1.0:0, tuners 1, state 4, standards 3
Jan 23, 2021 01:21:15.555 [0x7f1289218640] INFO - [I] device_manager_t::get_device_list. Device dualHD, id dvb#v4l#0#/sys/devices/pci0000:00/0000:00:14.0/usb3/3-9/3-9:1.0:1, tuners 1, state 5, standards 3
Jan 23, 2021 01:21:15.555 [0x7f1289218640] INFO - [I] device_manager_t::scan_get_channels. Device dvb#v4l#0#/sys/devices/pci0000:00/0000:00:14.0/usb3/3-9/3-9:1.0:1
Jan 23, 2021 01:21:15.555 [0x7f1289218640] INFO - [I] device_manager_t::scan_get_log. Device dvb#v4l#0#/sys/devices/pci0000:00/0000:00:14.0/usb3/3-9/3-9:1.0:1
Related topic:
I am following this up. Is it only DVB-C ?
