Plex wont install...still
Server Version#:1.32.8 "whatever current version download is
https://prnt.sc/ztbabMZ-vpe9
literally still having this issue, had this issue a few months ago found a fix but not the same fix doesn’t work.
sits at initialize and does nothing. Can’t believe this isssue still persist.
fresh install windows 11 all update.
all required drivers installed
internet works perfectly fine
i shouldn’t have to go through 7000000000 million pages on of articles on google to fix this. it shoudl’ve been fixed in the installer.
one thing i do know the older versions do work just fine… maybe i dont i can’t remember. but yes i think thats what i had to do last time install a very old version to get this to work…
why am i having this issue and why does the fix the support article gives not working anymore?
again to fix this issue i removed all traces of Plex in all folders and removed the Registry entry as well “very much needed if you want to reinstall”
this is the version i installed
PlexMediaServer-1.30.0.6486-629d58034-x86_64
and it works just fine installing…
can we get a fix on these newer installers please???
