See image. I went through and made sure everything was named the same, Plex recognized the subs for a moment then went back to this
Please copy the content of the ``guid="…` property from the Plex XML info of that episode.
Document.txt (1.8 KB)
Do you have the display of file name extensions enabled or disabled (default) in Windows?
This can produce confusion about what the actual file name is.
I recommend you to enable it. https://www.howtogeek.com/205086/beginner-how-to-make-windows-show-file-extensions/
- Try to use 3-letter language codes (e.g.
enginstead ofen) - After adding fresh subtitles, “Refresh Metadata” of the whole tv show
- use square brackets to hide parts of the folder and file names from Plex, which are not part of the official file naming schema
e.g.
/Drake & Josh (2004)
/Season 01 [2004]
Drake & Josh (2004) - s01e01 - Hug Me, Brother (Pilot) [480p AMZN Web-DL].mp4
Drake & Josh (2004) - s01e01 - Hug Me, Brother (Pilot) [480p AMZN Web-DL].eng.srt
I’d already tried three letter suffix, and the file extension display was correct. I added brackets and refreshed metadata and that’s working so far
