Plex won't update?????????
Why does it continuously say Plex requires an update then it install and whenever I try to open the app it tells me it needs an update again??? What happened to this app it was just working???
I’ve tried uninstalling the app, rebooting the Xbox, re-downloading the app from the store. nothing works. Please rollback this update dummies.Or fix the bug.
Go to your “My games & apps” section and delete every PLEX app you have (if you have 2 delete them both)
Then go to the store and look for “Plex for Xbox One” and install that one.
If you have pinned the old app also remove this Pin and Pin the new one after installing.
