On the list!
I stayed with Plexamp 1.1 due to understandable reality that “Plex Companion”/“Remote Control”/“cast” abilities weren’t available yet in Plexamp 3. But now it seems SSL certificate within the Plexamp 1.1 package expired Sep 30, so it can no longer connect to Plex Media Server. So I’m dead in the water until Plexamp release (on raspberry pi) arrives with the remote-control-ability added…
Anyone find a work-around, by chance? (other than changing the date clock on my raspberry pi.)
I’m using plexamp on a rpi as described here , control it from my android tablet, and did not notice a ssl deprecation, maybe you can use that version @danberndt ?
Thanks @euri10 for the suggestion. I did try this exactly as outlined, but I’m still seeing same exact problem, so now really at a complete loss.
From log:
Oct 07 00:54:26 raspi node[7342]: warn: DEVICE: Server connection https://192.168.1.11:32400 didn’t work for Dan’s Media: certificate has expired
Oct 07 00:54:26 raspi node[7342]: warn: DEVICE: Connection testing failed for Dan’s Media
Oct 07 00:54:26 raspi node[7342]: warn: DEVICE: Player connection https://67.68.69.142:56789 didn’t work for Safari: certificate has expired
Oct 07 00:54:26 raspi-dr node[7342]: warn: DEVICE: Connection testing failed for Safari
Oct 07 00:54:26 raspi-dr node[7342]: error: DEVICE: Error loading media providers from plex.tv: Error: Request failed with status code 406
Did you see this thread? It looks like you’re running into an expired cert, and this thread has an apparent fix
Yup… also discovered that post… and it worked! Thanks for the pointer… PROBLEM SOLVED!
