Plexamp for Raspberry Pi Release Notes
Plexamp for Raspberry Pi v2.0 beta 2
We’re pleased to announce the next release of Plexamp for Raspberry Pi, with massive internal changes and improvements. The audio engine inside is the exact same upgraded piece of awesome which powers our iOS and Android apps. Overall, the biggest changes:
  • Support for TIDAL and podcasts.
  • Lower memory usage.
  • Much faster startup of playback in many cases.
  • Much faster seeking/track skipping (in many cases instant).
  • Pre-buffering of next track.
  • Improved sweet Fades (smart overlaps) between tracks.
  • Soft fadeout when pausing/skipping.
  • Transcoding into Opus for high bitrate remote media.
This is a beta release, so we’d appreciate your feedback on it. We’ll likely be adding more configurability, specifically.
We recommend this hat for digital audio, it’s cheap and high quality.
  1. Download https://files.plexapp.com/elan/Plexamp-v2.0.0-rPi-beta.2.tar.bz2
  2. Get a server.json file from existing Plexamp on desktop install, install in /home/pi/.config/Plexamp/. Sign out and back into your existing install to get a new identifier/token.
  3. Install node 9 on the Pi.
$ curl -sL https://deb.nodesource.com/setup_9.x | sudo -E bash -
$ sudo apt install -y nodejs
  1. Unpack in /home/pi
  2. Install service file:
$ sudo cp /home/pi/plexamp/plexamp.service /lib/systemd/system/plexamp.service
  1. Get service running:
$ sudo systemctl daemon-reload
$ sudo systemctl enable plexamp
$ sudo systemctl start plexamp
$ sudo systemctl status plexamp
Plexamp on Headless Pi & Tidal
Suggestions for the future: Headless RPi support!
Separate rpi to control speakers
Remote Control of Tidal via Android App on Plexmp or PMP
Plexamp for Raspberry Pi - Node incompatibility
Noob Step by Step for Plexamp install on Pi2
Plexamp Raspberry Pi, Direct Play FLAC?
Plexamp on Headless Pi Issue
Playing plex music on an pi
How to cast plexamp to pi
How to setup Plexamp on RPI4 with DAC and a touchscreen?
Plexamp 3.0 desktop: no more casting to it?
Raspberry Pi Plexamp Tidal Integration
Music player controlled remotely. Can this be done?
Plexamp for Raspberry Pi - Running but not available to cast to
Plexamp 3.0 is not averrable in Select player via Plex app(standalone or web) interface
Tried everything but Plex Pass audio features won't work
PlexAmp player on ubuntu server
Raspberry ALexa
What Plex Client To install On Raspberry Pi 3B+?
Can I cast to PlexAmp For Raspberri Pi From plex app on Mobile?
How can I stream from Plexamp on Mac to a Raspberry Pi without losing thing like fades?
Shuffle is playing the same tracks repeatedly
Plexamp on Raspberry Pi as a streaming device
Plex als reiner Musik Client
PLEX to control CAMBRIDGE STREAM MAGIC via DLNA
How to use Plex app or Plexamp to play music on home stereo
Future of Plexamp on Raspberry Pi?
Streaming audio to Raspberry pi with Allo Digione as a Plex client?
Plexamp for Raspberry, cannot start playback on Android phone when casting
Plex Server and advertise as a Player
Plexamp and Hi-Fi
Raspberry Pi 4 as a Headless Music client?
Configuration settings for playing audio on a specific channel of a USB audio device connected to Raspberry Pi
Workaround for incompatiblity with newer versions of Raspbian:
Superseded by Plexamp on the Raspberry Pi - #10 by elan
