Plexamp 3.0 does not start on Windows 10 VM
Plexamp 1.1 worked, but Plexamp 3.0 just won’t start. At first I thougt maybe because I installed 3.0 over 1.1, but I uninstalled and deleted all Plexamp Stuff and reinstalled.
There are only 4 Plexamp threads in task manager but no UI.
OS is Windows 10 1909 on VirtualBox 5.2.37
I found this log:
Apr 17, 2020 10:14:00.849 [Javascript] INFO - METRICS: Initializing.
Apr 17, 2020 10:14:00.850 [Javascript] INFO - USER: Refreshing users.
Apr 17, 2020 10:14:00.851 [Javascript] INFO - DEVICE: Error loading resources.
Apr 17, 2020 10:14:00.851 [Javascript] WARNING - METRICS: Cannot start up, no token.
Apr 17, 2020 10:14:00.851 [Javascript] INFO - USER: Loaded 0 users
Apr 17, 2020 10:14:00.851 [Javascript] WARNING - DEVICE: Cannot initialize, no token.
Apr 17, 2020 10:14:00.853 [Javascript] INFO - ACCOUNT: Refreshing data.
Apr 17, 2020 10:14:00.859 [Javascript] INFO - Audio: Initializing.
Apr 17, 2020 10:14:00.859 [Javascript] INFO - Audio: Binding settings.
Apr 17, 2020 10:14:00.859 [Javascript] INFO - Audio: Setting player info.
Apr 17, 2020 10:14:00.860 [0x00001e90] DEBUG - BASS: Starting up.
Apr 17, 2020 10:14:00.868 [0x00001e90] INFO - BASS: Device 1: Default - enabled default - sample rates:
Apr 17, 2020 10:14:00.868 [0x00001e90] INFO - BASS: Device 2: Lautsprecher (High Definition Audio Device) - enabled default handset hdmi headset line speakers - sample rates:
Apr 17, 2020 10:14:00.868 [0x00001e90] DEBUG - BASS: Using plugin path 'C:\Users\User\AppData\Local\Programs\Plexamp\resources\treble/'.
Apr 17, 2020 10:14:00.886 [0x00001e90] INFO - BASS: Loaded ALAC plug-in version 2.4.0.0
Apr 17, 2020 10:14:00.901 [0x00001e90] INFO - BASS: Loaded FLAC plug-in version 2.4.4.2
Apr 17, 2020 10:14:00.917 [0x00001e90] INFO - BASS: Loaded OPUS plug-in version 2.4.1.12
Apr 17, 2020 10:14:00.933 [0x00001e90] INFO - BASS: Loaded APE plug-in version 2.4.2.0
Apr 17, 2020 10:14:00.950 [0x00001e90] INFO - BASS: Loaded MPC plug-in version 2.4.1.2
Apr 17, 2020 10:14:00.950 [0x00001e90] INFO - BASS: Core version 2.4.15.0
Apr 17, 2020 10:14:00.950 [0x00001e90] INFO - BASS: Mixer version 2.4.9.0
Apr 17, 2020 10:14:00.950 [0x00001e90] INFO - BASS: FX version 2.4.12.1
Apr 17, 2020 10:14:00.950 [0x00001e90] INFO - BASS: Curl version is libcurl/7.64.1-DEV OpenSSL/1.1.0j zlib/1.2.11
Apr 17, 2020 10:14:00.953 [Javascript] INFO - Network changed: type is unknown effectiveType is 4g -> 2
Apr 17, 2020 10:14:00.953 [0x00001e90] INFO - BASS: Network switched to 2.
Apr 17, 2020 10:14:00.954 [Javascript] INFO - Sync: Storing files to C:/Users/User/AppData/Local/Plexamp/Plexamp/Offline
Apr 17, 2020 10:14:00.956 [0x000016ac] INFO - Cache: Max size was 512 MB, deleted 0 files in cache, 0.0 MB remain.
Apr 17, 2020 10:14:00.958 [Javascript] INFO - Player: Initializing with state null
Apr 17, 2020 10:14:00.961 [Javascript] INFO - Network changed: type is unknown effectiveType is 4g -> 2
Apr 17, 2020 10:14:00.962 [Javascript] INFO - Sync: new network type 2
Apr 17, 2020 10:14:00.965 [Javascript] INFO - ViewState: Error loading from storage. Unexpected token u in JSON at position 0
Apr 17, 2020 10:14:00.965 [Javascript] INFO - Cloud: Error loading from storage. Unexpected token u in JSON at position 0
Apr 17, 2020 10:14:00.966 [Javascript] INFO - Shortcuts: Initializing!
Apr 17, 2020 10:14:00.968 [Javascript] INFO - Init: Stores all initialized.
Apr 17, 2020 10:14:00.990 [Javascript] INFO - Auth: Requesting PIN.
Apr 17, 2020 10:14:00.991 [Javascript] WARNING - Animated: `useNativeDriver` is not supported because the native animated module is missing. Falling back to JS-based animation. To resolve this, add `RCTAnimation` module to this app, or remove `useNativeDriver`. More info: https://github.com/facebook/react-native/issues/11094#issuecomment-263240420
Apr 17, 2020 10:14:00.996 [Javascript] INFO - Init: Booting complete.
Apr 17, 2020 10:14:01.274 [Javascript] INFO - Auth: Got PIN response.
Apr 17, 2020 10:14:05.964 [Javascript] INFO - Sync: Looking for incomplete items.
No replies on that issue?
I have the same problem, but in physical machine.
