Plexamp 3.0 is not averrable in Select player via Plex app(standalone or web) interface
Is this indented or bug?
Intended for now.
omg, so basically that killed my whole workflow, is there a way how to downgrade back to 1.10? because when I tried via brew cask (mac os) it was downloading the 1.10 version, but after the installation I ended up with 3.0 :frowning:
just give you an idea why this is important, the ‘native’ plex app for mac doesn’t support gapless playback, so I was using plexamp and controlling via plex app, because my music collection is quite big and its much easier to search and mostly important to SEE what I’m looking for. This is indeed sad day for me. I was looking forward for the new version (especially one for RPI as well, but there is only linux x86 available, I’m disappoint)
There is actually a RasPi port of Plexamp2.0 available. It might still work for you. Plexamp for Raspberry Pi Release Notes
I know, but once again, the crossfade is enabled. I know about server.json, but it seems that sometimes it doesn’t respect that setting :frowning: I’m sorry, but I have to look elsewhere for different solution (roon $$$$$)).
Might one ask why?
My work flow is to browse via Plex app on my iPad and play on Plexamp on my Mac mini (headless). This gives me best sound quality and has replaced Sonos.
You telling me plexamp 3 removes this functionality?
yes, i was using it same way :frowning:
I’ve run into the same issue as well. By my understanding, the app was rebuilt from the ground up using an entirely different codebase, so I don’t think the feature was removed so much as they simply didn’t have time to re-implement it before the official release.
All other posts I have read indicate that Casting support is on the roadmap. In the meantime, for our specific applications it probably makes sense to revert to 1.1.0
Correct. Casting/Companion features are in the works and are definitely in the near future.
