Plexamp 4.8.2 Quitting Unexpectedly when clicking back in Settings
Server Version#:
Player Version#: Plexamp 4.8.2
When using Plexamp and going into Settings when I click back the app quits unexpectedly. I need a little help on what logs I should send and where to find them.
thank you.
-matt.
if you’re on MacOS, go to Finder > Go > Go To Folder …
and enter ~/Library/Logs/Plexamp
(actually, devs might already have some crash data from you … but if they also need logs, that’s where to find them)
Hrm. I only have Plex, no Plexamp for logs.
SCR-20230824-imxy
did you download and install Plexamp from here?
https://www.plex.tv/plexamp/#downloads
i just installed the iOS version installed on a Mac … now i’m seeing similar behavior and crashes as what you’re describing … try the Mac version from my post above, expect that will help
OH! I didn’t know that version existed. OK, going to get it now!
That did it! Thank you @tgp-2 I really appreciate it!
