PLEXAMP - Ability to scroll the Visualizers (Android TV)
Hi Plex LABS Team…
Don’t ignore this request… I understand that PLEXAMP not supported on Android Tv. However sideloading work beautifully and as a someone own a PLEX PASS, I am enjoying the app.
I got a small request for the developers for this app in Android. When someone select the “Select Visualizer” can you set focus on the “Visualizer” overlay? This will allow the TV remote to navigate to the bottom of the screen as per screenshot and select the other “Visualizers”.
This is a small request and hope you will help…
Current issue is via the D-Pad or remote, unable to navigate to the bottom of the list…
P.S: I am using this in my Shield TV and thanks to Nvidia GUP the Visualizers are awesome…
not ignoring the request, but that would take some work to do (focus is basically the hardest part of tv/d-pad platforms). not even sure what it would entail :sweat_smile:
Thanks. The scroll bar is visible but the shield trackpad mouse not able to click it. No rush and have a look when time permits.
BTW Plexamp currently not supporting MFA. I had to disable it to login to Plexamp.
it’s fixed in the next release (just waiting for stores to finish reviewing).
I found the solution to my own issue… hope this will help others on Shield TV…
You can scroll via Shield TV - Mobile APP remote → Track Pad mode and HOLD LEFT Click button and scroll…
Attached an image to show this…
awesome to hear, thanks for sharing!
Not necessary. Simply attach the 2FA code directly after the password.
