Plexamp as a remote control
I just wanna start off with saying that I love the new mini Plex player for my audio!
I tried using the player dropdown menu to select remote players within my home network (1 PC, 2 MACs, 1 PS4, 1 IOS) all with clients active. Unfortunately nothing shows up besides Local.
This does work when I try it the other way around and use any other client to connect to the Plexamp and play something.
Can you help me further?
thanks in advance,
T
sorry couldn’t get the file to upload.
May 17, 2018 22:09:05.351 INFO - Starting app…
May 17, 2018 22:09:07.522 DEBUG - Window bounds is 1372 x 583.
May 17, 2018 22:09:07.583 INFO - Adding key mapping: MediaNextTrack -> next
May 17, 2018 22:09:07.586 INFO - Adding key mapping: MediaPlayPause -> playpause
May 17, 2018 22:09:07.587 INFO - Adding key mapping: MediaPreviousTrack -> previous
May 17, 2018 22:09:07.587 INFO - Adding key mapping: Shift+CommandOrControl+Space -> activate
May 17, 2018 22:09:07.587 INFO - Adding key mapping: Shift+Command+Control+Option+0 -> unrate
May 17, 2018 22:09:07.587 INFO - Adding key mapping: Shift+Command+Control+Option+1 -> rate1
May 17, 2018 22:09:07.588 INFO - Adding key mapping: Shift+Command+Control+Option+2 -> rate2
May 17, 2018 22:09:07.588 INFO - Adding key mapping: Shift+Command+Control+Option+3 -> rate3
May 17, 2018 22:09:07.588 INFO - Adding key mapping: Shift+Command+Control+Option+4 -> rate4
May 17, 2018 22:09:07.589 INFO - Adding key mapping: Shift+Command+Control+Option+5 -> rate5
May 17, 2018 22:09:07.589 INFO - Adding key mapping: Shift+CommandOrControl+Option+Right -> nextalbum
May 17, 2018 22:09:07.589 INFO - Adding key mapping: CommandOrControl+Option+Up -> volumeup
May 17, 2018 22:09:07.590 INFO - Adding key mapping: CommandOrControl+Option+Down -> volumedown
May 17, 2018 22:09:07.591 DEBUG - UPDATES: Using latest channel.
May 17, 2018 22:09:07.627 INFO - Checking for update
May 17, 2018 22:09:08.265 INFO - Update for version 1.0.5 is not available (latest version: 1.0.5, downgrade is disallowed.
May 17, 2018 22:09:08.265 DEBUG - Autoupdate: Update is not available.
May 17, 2018 22:09:08.316 INFO - METRICS: Initializing.
May 17, 2018 22:09:08.316 INFO - ACCOUNT: Refreshing data.
May 17, 2018 22:09:08.317 INFO - DEVICE: Initializing manager.
May 17, 2018 22:09:08.318 INFO - DEVICE: Fetching latest provider list from cloud.
May 17, 2018 22:09:08.318 INFO - DEVICE: Fetching latest list from cloud.
May 17, 2018 22:09:08.319 INFO - DEVICE: Starting connection test.
May 17, 2018 22:09:08.319 INFO - DEVICE: Finding best connection for DiskStation
May 17, 2018 22:09:08.320 INFO - HTTP: Issuing request to https://127.0.0.1:32400/
May 17, 2018 22:09:08.320 INFO - HTTP: Issuing request to https://10.0.0.20:32400/
May 17, 2018 22:09:08.320 INFO - HTTP: Issuing request to https://192.168.0.200:32400/
May 17, 2018 22:09:08.320 INFO - HTTP: Issuing request to https://xx.xxx.xxx.xx:32400/
May 17, 2018 22:09:08.394 WARN - DEVICE: Server connection https://127.0.0.1:32400 didn’t work for DiskStation: connect ECONNREFUSED 127.0.0.1:32400
May 17, 2018 22:09:08.453 INFO - HTTP: Issuing request to https://192.168.0.200:32400/hubs/sections/7?count=4&includeLibraryPlaylists=1&includeStations=1&excludeFields=summary
May 17, 2018 22:09:08.549 INFO - METRICS: Saving latest cloud settings for metrics.
May 17, 2018 22:09:08.601 INFO - DEVICE: Fetched 8 devices from the cloud.
May 17, 2018 22:09:08.642 INFO - DEVICE: Server connection worked for DiskStation ~ https://xx.xxx.xxx.xx:32400
May 17, 2018 22:09:08.642 INFO - HTTP: Issuing request to https://xx.xxx.xxx.xx:32400/library/sections
May 17, 2018 22:09:08.644 INFO - DEVICE: Server connection worked for DiskStation ~ https://192.168.0.200:32400
May 17, 2018 22:09:08.644 INFO - DEVICE: Updating with better local connection.
May 17, 2018 22:09:08.758 INFO - DEVICE: 3 libraries at DiskStation: Movies,Music,TV Shows
May 17, 2018 22:09:08.758 INFO - DEVICE: Fast-path connection testing.
May 17, 2018 22:09:08.758 INFO - DEVICE: Finding best connection for Thierry Michel Philippe Kleist
May 17, 2018 22:09:08.759 INFO - HTTP: Issuing request to http://192.168.0.41:32500/
May 17, 2018 22:09:08.759 INFO - DEVICE: Finding best connection for Plex for PlayStation 4
May 17, 2018 22:09:08.759 INFO - HTTP: Issuing request to https://10.0.0.20:32400/resources
May 17, 2018 22:09:08.759 INFO - HTTP: Issuing request to https://192.168.0.200:32400/resources
May 17, 2018 22:09:08.761 INFO - HTTP: Issuing request to https://xx.xxx.xxx.xx:32400/resources
May 17, 2018 22:09:08.761 INFO - DEVICE: Finding best connection for Safari
May 17, 2018 22:09:08.762 INFO - HTTP: Issuing request to https://10.0.0.20:32400/resources
May 17, 2018 22:09:08.762 INFO - HTTP: Issuing request to https://192.168.0.200:32400/resources
May 17, 2018 22:09:08.763 INFO - HTTP: Issuing request to https://xx.xxx.xxx.xx:32400/resources
May 17, 2018 22:09:08.763 INFO - DEVICE: Finding best connection for Thierry’s MBP.fritz.box
May 17, 2018 22:09:08.763 INFO - HTTP: Issuing request to http://192.168.0.25:36000/resources
May 17, 2018 22:09:08.763 INFO - DEVICE: Finding best connection for Macbook
May 17, 2018 22:09:08.764 INFO - HTTP: Issuing request to http://192.168.0.25:36000/resources
May 17, 2018 22:09:08.764 INFO - DEVICE: Persisting devices.
May 17, 2018 22:09:08.770 INFO - DEVICE: Initialization finished in 452ms.
May 17, 2018 22:09:08.771 INFO - APP: Refreshing player/server menu.
May 17, 2018 22:09:08.777 WARN - DEVICE: The player 25b754fd-90be-44d5-8b73-10c95a9d73c7 wasn’t found in available resources at http://192.168.0.25:36000.
May 17, 2018 22:09:08.777 WARN - DEVICE: Connection testing failed for Thierry’s MBP.fritz.box
May 17, 2018 22:09:08.778 WARN - DEVICE: The player 452733f1-529d-4c85-9713-86079cdaabe6 wasn’t found in available resources at http://192.168.0.25:36000.
May 17, 2018 22:09:08.778 WARN - DEVICE: Connection testing failed for Macbook
May 17, 2018 22:09:08.807 WARN - DEVICE: Server connection http://192.168.0.41:32500 didn’t look like it hit the right server Thierry Michel Philippe Kleist
May 17, 2018 22:09:08.807 WARN - DEVICE: Connection testing failed for Thierry Michel Philippe Kleist
May 17, 2018 22:09:09.051 WARN - DEVICE: The player atl2zgsrfljzyhnfi86dk4l3 wasn’t found in available resources at https://192.168.0.200:32400.
May 17, 2018 22:09:09.051 WARN - DEVICE: The player bakk33ruqctct580hk8ads60 wasn’t found in available resources at https://192.168.0.200:32400.
May 17, 2018 22:09:09.056 WARN - DEVICE: The player atl2zgsrfljzyhnfi86dk4l3 wasn’t found in available resources at https://xx.xxx.xxx.xx:32400.
May 17, 2018 22:09:09.060 WARN - DEVICE: The player bakk33ruqctct580hk8ads60 wasn’t found in available resources at https://xx.xxx.xxx.xx:32400.
May 17, 2018 22:09:09.812 INFO - Another new request came in, tossing data (looking for: 1, was: 2)
May 17, 2018 22:09:13.361 WARN - DEVICE: Server connection https://10.0.0.20:32400 didn’t work for DiskStation: timeout of 5000ms exceeded
May 17, 2018 22:09:13.873 INFO - APP: Switching to new player 53m0h7ur6dxxmk4af7q281tt
May 17, 2018 22:09:13.873 WARN - DEVICE: Player connection https://10.0.0.20:32400 didn’t work for Plex for PlayStation 4: timeout of 5000ms exceeded
May 17, 2018 22:09:13.874 WARN - DEVICE: Connection testing failed for Plex for PlayStation 4
May 17, 2018 22:09:13.874 ERROR - PLAYER: Error issuing request to player macbook: /player/timeline/poll?wait=0&includeMetadata=1&commandID=3&type=audio connect ECONNREFUSED 192.168.0.25:32433
May 17, 2018 22:09:13.878 ERROR - PLAYER: Unable to poll the player, not switching.
May 17, 2018 22:09:13.878 INFO - APP: Refreshing player/server menu.
May 17, 2018 22:09:13.883 INFO - DEVICE: Fetching latest provider list from cloud.
May 17, 2018 22:09:13.884 INFO - DEVICE: Fetching latest list from cloud.
May 17, 2018 22:09:13.884 WARN - DEVICE: Player connection https://10.0.0.20:32400 didn’t work for Safari: timeout of 5000ms exceeded
May 17, 2018 22:09:13.884 WARN - DEVICE: Connection testing failed for Safari
May 17, 2018 22:09:13.884 INFO - APP: Refreshing player/server menu.
May 17, 2018 22:09:13.948 INFO - DEVICE: Fetched 8 devices from the cloud.
May 17, 2018 22:09:13.949 INFO - DEVICE: Finding best connection for Thierry Michel Philippe Kleist
May 17, 2018 22:09:13.949 INFO - HTTP: Issuing request to http://192.168.0.41:32500/
May 17, 2018 22:09:13.949 INFO - DEVICE: Finding best connection for Plex for PlayStation 4
May 17, 2018 22:09:13.950 INFO - HTTP: Issuing request to https://10.0.0.20:32400/resources
May 17, 2018 22:09:13.950 INFO - HTTP: Issuing request to https://192.168.0.200:32400/resources
May 17, 2018 22:09:13.950 INFO - HTTP: Issuing request to https://xx.xxx.xxx.xx:32400/resources
May 17, 2018 22:09:13.950 INFO - DEVICE: Finding best connection for Safari
May 17, 2018 22:09:13.951 INFO - HTTP: Issuing request to https://192.168.0.200:32400/resources
May 17, 2018 22:09:13.951 INFO - HTTP: Issuing request to https://xx.xxx.xxx.xx:32400/resources
May 17, 2018 22:09:13.951 INFO - DEVICE: Finding best connection for Thierry’s MBP.fritz.box
May 17, 2018 22:09:13.951 INFO - HTTP: Issuing request to http://192.168.0.25:36000/resources
May 17, 2018 22:09:13.951 INFO - DEVICE: Finding best connection for Macbook
May 17, 2018 22:09:13.958 WARN - DEVICE: The player 25b754fd-90be-44d5-8b73-10c95a9d73c7 wasn’t found in available resources at http://192.168.0.25:36000.
May 17, 2018 22:09:13.958 WARN - DEVICE: Connection testing failed for Thierry’s MBP.fritz.box
May 17, 2018 22:09:13.959 WARN - DEVICE: The player 452733f1-529d-4c85-9713-86079cdaabe6 wasn’t found in available resources at http://192.168.0.25:36000.
May 17, 2018 22:09:13.959 WARN - DEVICE: Connection testing failed for Macbook
May 17, 2018 22:09:14.092 WARN - DEVICE: Server connection http://192.168.0.41:32500 didn’t look like it hit the right server Thierry Michel Philippe Kleist
May 17, 2018 22:09:14.092 WARN - DEVICE: Connection testing failed for Thierry Michel Philippe Kleist
May 17, 2018 22:09:14.274 WARN - DEVICE: The player atl2zgsrfljzyhnfi86dk4l3 wasn’t found in available resources at https://192.168.0.200:32400.
May 17, 2018 22:09:14.280 WARN - DEVICE: The player bakk33ruqctct580hk8ads60 wasn’t found in available resources at https://192.168.0.200:32400.
May 17, 2018 22:09:14.281 WARN - DEVICE: The player atl2zgsrfljzyhnfi86dk4l3 wasn’t found in available resources at https://xx.xxx.xxx.xx:32400.
May 17, 2018 22:09:14.283 WARN - DEVICE: The player bakk33ruqctct580hk8ads60 wasn’t found in available resources at https://xx.xxx.xxx.xx:32400.
May 17, 2018 22:09:18.954 WARN - DEVICE: Player connection https://10.0.0.20:32400 didn’t work for Plex for PlayStation 4: timeout of 5000ms exceeded
May 17, 2018 22:09:18.954 WARN - DEVICE: Connection testing failed for Plex for PlayStation 4
May 17, 2018 22:09:18.954 WARN - DEVICE: Player connection https://10.0.0.20:32400 didn’t work for Safari: timeout of 5000ms exceeded
May 17, 2018 22:09:18.955 WARN - DEVICE: Connection testing failed for Safari
May 17, 2018 22:09:18.955 INFO - APP: Refreshing player/server menu.
May 17, 2018 22:09:23.147 INFO - DEVICE: Persisting devices because DiskStation was dirty.
May 17, 2018 22:09:23.148 INFO - DEVICE: Persisting devices.
