Plexamp - audiobook - 10sec to end
Server Version#: 1.32.5.7349
Player Version#: 4.8.2
Hello,
I play audiobooks through plexamp and have the problem when the audiobook jumps to the next chapter, it starts until 10 seconds before the end of the chapter.
So it jumps almost immediately to the next chapter.
How can I turn this off, have not yet found an option in the settings.
Thank for the help.
Try using Chronicle (android) instead. Seems to handle Audiobooks perfectly.
I presume this happens in books that you have played before. Does it happen on books that you’re playing for the very first time in Plex?
This is probably caused by the “Store track progress” setting. This causes Plex to remember the playing position of every track. This was the one attempt by Plex to provide some support for audiobooks. Unfortunately, it is only useful if your audiobook is in a single, monolithic file. If your books are in multiple files, it can cause issues like you’re seeing.
I have to agree with AmazingRando24 – Plex really isn’t the app for audio books.
