Plexamp playing songs not from beginning
Hello,
since years I am using plex. And it’s the best system.
especially with plexamp it is now almost perfect.
but I have a big problem with plexamp on android and windows which drives me nuts.
When I am playing a song which I already listened to again the song is not starting at the beginning but always starts with the last seconds and switches then to the next song. And there also to the last seconds if I had already listened to that song. it skips the whole song except the last seconds again. But only at the songs I have listened already.
I cannot find any option to change it.
But it is very bad because so you cannot listen to the songs.
I did not find any article about this problem. So I just wrote here. Please help.
thanks
BRGDS jochen
Disable the “Store Track Progress” preference in the library settings:
It’s off by default, and is only recommended for people using Plex Music libraries for long-form content like audiobooks.
Thanks for quick answer!
Now it’s working fine
