As mentioned in the title, I’m wondering if it would be possible for Plexamp to combine my Plex and Tidal libraries (instead of choosing one or the other in the settings).
I use my personal Plex library to fill the gaps of the Tidal selection, and it would be great if I could choose to see them both as one combined library instead of needing to switch between the two.
Apologies if this has been requested already.
Not sure if this can be done from PlexAmp, but from Plex Web, there is an option to add Tidal content to your music library. Then you only need to look at your music library.
There is no way to combine or see both your music library and All of Tidal at once.
Thanks for the reply.
I have found that option. Unfortunately my use of my music libraries are on the go… but yes, functionality like that in Plexamp (or even the mobile version of Plex) is what I’m going for.
Like I said, I don’t know if Plexamp ahs that Add function, but once added, PlexAmp should be able to show Tidal content in your library.
