Plexamp constantly closing itself in the background while Casting
Plexamp has always seemed to have issues with staying open in the background while casting, but it’s gotten worse recently. I can see my phone constantly closing it out and opening it back up by looking at my lockscreen and seeing the currently playing song disappear and reappear multiple times a minute. I tried whitelisting the app from the phones built in battery saver features, but no luck.
Pixel 5. I attached some logs to this post.558326119424127.zip (162.6 KB)
Bumping this, hope to get some sort of reply and that the logs help.
Here’s some more logs I just collected of PlexAmp acting up while casting. 331275087848824 (1).zip (106.9 KB)
Anything? :pensive:
Your logs indicate the player service is being destroyed and recreated over and over again. There’s no indication of why it’s being destroyed, which usually means the OS is killing it because it doesn’t think it’s active.
There’s also this semi-suspicious line in the log:
Jan 18, 2021 16:10:38.435 [Javascript] WARNING - Error setting media session on media router.
Please see if you see this line whenever the problem occurs (and test with the latest release in case it helps).
Well, that sucks. I’m on Plexamp version 3.4.1 - according to my phone it’s the latest version available from the play store. It’s on a Pixel 5 running completely stock software, so no weird memory/battery saving apps to speak of…next time I cast I’ll pull another log and see if I spot that same line.
if it’s reproducible let us know and i’ll make you a build to try which logs more information with that error.
It’s definitely reproducible - it happens every time I cast music to my google home devices.
please see if that offending log line appears every time; if so, we can do some more diagnosis on it.
