Plexamp crashes when opening any Library view
Plexamp: 3.4.3
Plex Server: Latest Docker image
OS: Pixel 4a Android 11, Feb patch
I am not sure what caused it, but it happens despite force closing and wiping cache.
I am doing hw, and started the download of an album, it had finished downloading and I went to click on ‘artists’ to download a 2nd one.
Strangely enough every other view works. It only crashes on the Artists/Albums/Tracks views. Folders, labels, and moods works fine.
Even stranger, if I switch to Tidal as my music source, all the views load fine. I suspect the Plex server is sending some image or metadata that is crashing the application.
I saw the iOS crash thread regarding downloading an entire library. I do have ~11gb in downloaded content (Fresh <3, and a few albums), I dont know if this is pushing the limits of what plexamp intends.
How can I get logs that are relevant to this crash?
Edit: logcat
03-05 07:18:26.322 32160 10732 E CastSocket: java.nio.channels.ClosedChannelException
03-05 07:18:26.322 32160 10732 E CastSocket: 	at sun.nio.ch.SocketChannelImpl.shutdownOutput(SocketChannelImpl.java:842)
03-05 07:18:26.322 32160 10732 E CastSocket: 	at sun.nio.ch.SocketAdaptor.shutdownOutput(SocketAdaptor.java:424)
03-05 07:18:26.322 32160 10732 E CastSocket: 	at ocm.l(:com.google.android.gms@210214046@21.02.14 (150400-352619232):4)
03-05 07:18:26.322 32160 10732 E CastSocket: 	at ocr.d(:com.google.android.gms@210214046@21.02.14 (150400-352619232):50)
03-05 07:18:26.322 32160 10732 E CastSocket: 	at ocq.run(:com.google.android.gms@210214046@21.02.14 (150400-352619232):2)
03-05 07:18:26.322 32160 10732 E CastSocket: 	at java.lang.Thread.run(Thread.java:923)
03-05 07:18:26.323 32160 10630 E CDC|API|98: [API] onSocketConnectionFailed; socketError="2 IO Error", controller state:Connecting
03-05 07:18:26.331 32160 10630 I CastSocketMultiplexer: Stopping multiplexer...
03-05 07:18:26.364 10567 10567 D AndroidRuntime: Shutting down VM
03-05 07:18:26.366 10567 10567 E AndroidRuntime: FATAL EXCEPTION: main
03-05 07:18:26.366 10567 10567 E AndroidRuntime: Process: tv.plex.labs.plexamp, PID: 10567
So sorry, just disable Blurred Action Bar and it’ll be all good. Fixed in the next release.
That’s crazy that that works :sweat_smile:
Thanks for the quick workaround Elan!
Waaay easier than searching for everything.
Edit:
Even more strange, with it disabled, I get a nice pop-up letter when tapping the Artist list scrubber, this is nice touch!
yep, we added this in the last release :sweat_smile:
