PlexAmp crashing after 2min | debian:sid
Server Version#: 1.41.5.9522
Player Version#: 4.12.3
running Plexamp on latest version of debian. Crashes reliable after 2 minutes even when doing nothing.
Logs from syslog:
May 13 08:34:31 xatian-pc Plexamp-4.12.3.AppImage[36328]: Main: restoring window state from /home/xatian/.config/Plexamp/window-state-plexamp-main.json
May 13 08:34:31 xatian-pc Plexamp-4.12.3.AppImage[36328]: Started Media Service: false
May 13 08:34:31 xatian-pc Plexamp-4.12.3.AppImage[36328]: Linux: Registering MPRIS service.
May 13 08:34:32 xatian-pc Plexamp-4.12.3.AppImage[36328]: Checking for update
May 13 08:34:32 xatian-pc Plexamp-4.12.3.AppImage[36328]: [36328:0513/083432.911685:ERROR:nss_util.cc(357)] After loading Root Certs, loaded==false: NSS error code: -8018
May 13 08:34:33 xatian-pc Plexamp-4.12.3.AppImage[36328]: Update for version 4.12.3 is not available (latest version: 4.12.3, downgrade is disallowed).
May 13 08:34:33 xatian-pc Plexamp-4.12.3.AppImage[36328]: checkForUpdatesAndNotify called, downloadPromise is null
May 13 08:36:31 xatian-pc Plexamp-4.12.3.AppImage[36371]: XIO: fatal IO error 22 (Invalid argument) on X server “:0”
May 13 08:36:31 xatian-pc Plexamp-4.12.3.AppImage[36371]: after 585 requests (585 known processed) with 0 events remaining.
May 13 08:36:31 xatian-pc Plexamp-4.12.3.AppImage[36328]: [36328:0513/083631.714402:ERROR:gpu_process_host.cc(993)] GPU process exited unexpectedly: exit_code=256
May 13 08:36:31 xatian-pc Plexamp-4.12.3.AppImage[36328]: Error: GPU process (undefined) abnormal-exit (256) :frowning:
May 13 08:36:31 xatian-pc Plexamp-4.12.3.AppImage[36328]: Quitting…
The line that shows the XIO-error is not always the same … I also found it saying this:
XIO: fatal IO error 88 (Socket operation on non-socket) on X server “:0”
Still it crashes always after 2minutes.
Please tell me if this is my fault and if so what I can do about it :slight_smile:
Thank you!
I also asked an AI with providing the error message. It suggested to start the app with “–disable-gpu” which seems to work and mitigate the crash. So I am happy. Maybe someone still wants to look at it :innocent:
