Plexamp - Discovery Mix, Loading Only 4 Songs
Experiencing this across a couple Windows installs and android. Below are logs from Android and a video: Imgur: The magic of the Internet
Discovery Radio only ever loads 4 songs, at the conclusion it will kick back to the main screen.
I should add that Tidal is playing normal for albums as far as I can tell.
141806457332519.zip (906.2 KB)
Discovery radio was my main use of Plexamp/Tidal and mine is broken exactly the same. 4 songs and in windows a banner below which used to say silence but now with the latest version says radio.
At the moment Plexamp is mostly useless for me. I’m getting my music via the Tidal website ‘daily discovery’ which does similar to discovery radio if more than a bit too predictable in its choices.
Artist radios on tidal in Plex win 10 works OK so it is just a Plexamp thing.
Please fix it.
It’s a bug in the media server, which was just fixed! Sorry about that.
Thanks. No server update available since your post and Plexamp discovery radio still the same. Guess it takes a while to work through the system.
Look forward to it getting released.
Yeah, the fix has not even been reviewed yet :sweat_smile:
Got all excited as an update for the server was available. No change after though - still 4 songs and out.
Any idea how long it takes for a fix to get through the system?
