Random tracks albums failing to play cause discovery radio to hang
I’ve been having an issue lately with random albums and tracks failing to play from Tidal. There seems to be no connection, sometimes a single album from an artist won’t play other time several. (If anyone wants to check these albums always fail for me: Modern Baseball, you’re all gonna miss it all - The Menzingers, Hello Exile - Most live albums by Red Hot Chilli Peppers) The knock on effect is that discovery radio takes ages to load and when it does it may or may not stop immediately depending on whether it can play the first track. I’ve tried all the usual things like un-linking and re-linking tidal. The same tracks fail in all other players too. When a track fails this is the error in the console - “Exception handled: bad lexical cast: source type value could not be interpreted as target”
