Plexamp - Album radio & Show similar tracks - Not working with Tidal library
The title says it all really. Doesn’t matter if using Android, Linux Appimage, or Windows desktop. Using version 4.5.3 I get the message, “Unable to load data. This makes me sad” - and it does… :frowning:
Edit: Result of requesting similar tracks:
Nov 20, 2022 14:45:08.197 [Javascript] INFO - Error loading: get https://music.provider.plex.tv/library/metadata/5bd1054eb128be001c35268b/nearest?limit=50&maxDistance=0.25&excludeGrandparentID=5ba004803e9baa001c5b46b9&excludeFields=summary&excludeElements=Media,Director,Country&sort=distance:desc: HTTP status 500
Thanks, we fixed the menu items showing up when they wasn’t supposed to be.
Thanks for the quick reply. I didn’t respond at the same pace as I wasn’t quite sure what you meant & thought I’d just wait for the next version to find out. Now that 4.6.0 is here I understand - those menu entries have been removed. I wasn’t aware that they shouldn’t be there as I’m still exploring the app. While I’m happy that a bug is fixed, I’m sad that there’s no album or track radio for my Tidal library. Is there any plans to implement such features?
If and when we have data for it, yes.
Data for similar albums should be available directly from Tidal. I know that you’re not using this & that it’s unofficial, but just as an example see: API Reference — tidalapi 0.7.0 documentation
