I can’t run the plexamp app on my ubuntu. It just sits there.
~/Downloads$ uname -a
Linux mysystem 5.13.0-37-generic #42~20.04.1-Ubuntu SMP Tue Mar 15 15:44:28 UTC 2022 x86_64 x86_64 x86_64 GNU/Linux
~/Downloads$ strace ./Plexamp-4.1.0.AppImage --no-sandbox
execve("./Plexamp-4.1.0.AppImage", ["./Plexamp-4.1.0.AppImage", “–no-sandbox”], 0x7fffdb596498 /* 49 vars /) = 0
brk(NULL) = 0x1063000
arch_prctl(0x3001 / ARCH_??? /, 0x7ffdc4d877a0) = -1 EINVAL (Invalid argument)
access("/etc/ld.so.preload", R_OK) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, “/etc/ld.so.cache”, O_RDONLY|O_CLOEXEC) = 3
fstat(3, {st_mode=S_IFREG|0644, st_size=104055, …}) = 0
mmap(NULL, 104055, PROT_READ, MAP_PRIVATE, 3, 0) = 0x7f0d637bf000
close(3) = 0
openat(AT_FDCWD, “/lib/x86_64-linux-gnu/libdl.so.2”, O_RDONLY|O_CLOEXEC) = 3
read(3, “\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0 \22\0\0\0\0\0\0”…, 832) = 832
fstat(3, {st_mode=S_IFREG|0644, st_size=18816, …}) = 0
mmap(NULL, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x7f0d637bd000
mmap(NULL, 20752, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f0d637b7000
mmap(0x7f0d637b8000, 8192, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x1000) = 0x7f0d637b8000
mmap(0x7f0d637ba000, 4096, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x3000) = 0x7f0d637ba000
mmap(0x7f0d637bb000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x3000) = 0x7f0d637bb000
close(3) = 0
openat(AT_FDCWD, “/lib/x86_64-linux-gnu/libpthread.so.0”, O_RDONLY|O_CLOEXEC) = 3
read(3, “\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\220q\0\0\0\0\0\0”…, 832) = 832
pread64(3, “\4\0\0\0\24\0\0\0\3\0\0\0GNU\0\360\2300%\360\340\363’\246\332u/\364\377\246u”…, 68, 824) = 68
fstat(3, {st_mode=S_IFREG|0755, st_size=157224, …}) = 0
mmap(NULL, 140408, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f0d63794000
mmap(0x7f0d6379a000, 69632, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x6000) = 0x7f0d6379a000
mmap(0x7f0d637ab000, 24576, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x17000) = 0x7f0d637ab000
mmap(0x7f0d637b1000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x1c000) = 0x7f0d637b1000
mmap(0x7f0d637b3000, 13432, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x7f0d637b3000
close(3) = 0
openat(AT_FDCWD, “/lib/x86_64-linux-gnu/libz.so.1”, O_RDONLY|O_CLOEXEC) = 3
read(3, “\177ELF\2\1\1\3\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\200”\0\0\0\0\0\0"…, 832) = 832
fstat(3, {st_mode=S_IFREG|0644, st_size=108936, …}) = 0
mmap(NULL, 110776, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f0d63778000
mprotect(0x7f0d6377a000, 98304, PROT_NONE) = 0
mmap(0x7f0d6377a000, 69632, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x2000) = 0x7f0d6377a000
mmap(0x7f0d6378b000, 24576, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x13000) = 0x7f0d6378b000
mmap(0x7f0d63792000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x19000) = 0x7f0d63792000
close(3) = 0
openat(AT_FDCWD, “/lib/x86_64-linux-gnu/libc.so.6”, O_RDONLY|O_CLOEXEC) = 3
read(3, “\177ELF\2\1\1\3\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\360A\2\0\0\0\0\0”…, 832) = 832
pread64(3, “\6\0\0\0\4\0\0\0@\0\0\0\0\0\0\0@\0\0\0\0\0\0\0@\0\0\0\0\0\0\0”…, 784, 64) = 784
pread64(3, “\4\0\0\0\20\0\0\0\5\0\0\0GNU\0\2\0\0\300\4\0\0\0\3\0\0\0\0\0\0\0”, 32, 848) = 32
pread64(3, “\4\0\0\0\24\0\0\0\3\0\0\0GNU\0\237\333t\347\262\27\320l\223\27 \202C\370T\177”…, 68, 880) = 68
fstat(3, {st_mode=S_IFREG|0755, st_size=2029560, …}) = 0
pread64(3, “\4\0\0\0\24\0\0\0\3\0\0\0GNU\0\237\333t\347\262\27\320l\223\27*\202C\370T\177”…, 68, 880) = 68
mmap(NULL, 2037344, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f0d63586000
mmap(0x7f0d635a8000, 1540096, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x22000) = 0x7f0d635a8000
mmap(0x7f0d63720000, 319488, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x19a000) = 0x7f0d63720000
mmap(0x7f0d6376e000, 24576, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x1e7000) = 0x7f0d6376e000
mmap(0x7f0d63774000, 13920, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x7f0d63774000
close(3) = 0
mmap(NULL, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x7f0d63584000
arch_prctl(ARCH_SET_FS, 0x7f0d63584b80) = 0
mprotect(0x7f0d6376e000, 16384, PROT_READ) = 0
mprotect(0x7f0d63792000, 4096, PROT_READ) = 0
mprotect(0x7f0d637b1000, 4096, PROT_READ) = 0
mprotect(0x7f0d637bb000, 4096, PROT_READ) = 0
mprotect(0x7f0d63806000, 4096, PROT_READ) = 0
munmap(0x7f0d637bf000, 104055) = 0
set_tid_address(0x7f0d63584e50) = 163004
set_robust_list(0x7f0d63584e60, 24) = 0
rt_sigaction(SIGRTMIN, {sa_handler=0x7f0d6379abf0, sa_mask=, sa_flags=SA_RESTORER|SA_SIGINFO, sa_restorer=0x7f0d637a83c0}, NULL, 8) = 0
rt_sigaction(SIGRT_1, {sa_handler=0x7f0d6379ac90, sa_mask=, sa_flags=SA_RESTORER|SA_RESTART|SA_SIGINFO, sa_restorer=0x7f0d637a83c0}, NULL, 8) = 0
rt_sigprocmask(SIG_UNBLOCK, [RTMIN RT_1], NULL, 8) = 0
prlimit64(0, RLIMIT_STACK, NULL, {rlim_cur=8192*1024, rlim_max=RLIM64_INFINITY}) = 0
brk(0x1084000) = 0x1084000
openat(AT_FDCWD, “/proc/self/exe”, O_RDONLY) = 3
fstat(3, {st_mode=S_IFREG|0755, st_size=85942670, …}) = 0
read(3, “\177ELF\2\1\1\0AI\2\0\0\0\0\0\2\0>\0\1\0\0\0\220F@\0\0\0\0\0”…, 4096) = 4096
lseek(3, 0, SEEK_SET) = 0
lseek(3, 184320, SEEK_SET) = 184320
read(3, “\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0”…, 4096) = 4096
close(3) = 0
readlink("/proc/self/exe", “/home/stormcrow/Downloads/Plexam”…, 4096) = 48
futex(0x7f0d637bc0c8, FUTEX_WAKE_PRIVATE, 2147483647) = 0
close(3) = 0
openat(AT_FDCWD, “/lib/x86_64-linux-gnu/libfuse.so.2”, O_RDONLY|O_CLOEXEC) = 3
read(3, “\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\240\177\0\0\0\0\0\0”…, 832) = 832
fstat(3, {st_mode=S_IFREG|0644, st_size=252184, …}) = 0
mmap(NULL, 254240, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f0d63545000
mprotect(0x7f0d6354c000, 151552, PROT_NONE) = 0
mmap(0x7f0d6354c000, 106496, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x7000) = 0x7f0d6354c000
mmap(0x7f0d63566000, 40960, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x21000) = 0x7f0d63566000
mmap(0x7f0d63571000, 77824, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x2b000) = 0x7f0d63571000
close(3) = 0
mprotect(0x7f0d63571000, 73728, PROT_READ) = 0
getpid() = 163004
mkdir("/tmp/.mount_PlexamE62dNL", 0700) = 0
pipe([3, 4]) = 0
clone(child_stack=NULL, flags=CLONE_CHILD_CLEARTID|CLONE_CHILD_SETTID|SIGCHLD, child_tidptr=0x7f0d63584e50) = 163005
close(4) = 0
read(3,
~/Downloads$ ls -a /tmp|grep Plex
.mount_Plexam3Mc1ii
.mount_PlexamAi1EMX
.mount_PlexambHB5AZ
.mount_PlexamE62dNL
.mount_PlexamEACmXd
.mount_PlexamEBmTfl
.mount_PlexamIs5RA4
.mount_PlexamjrDUzq
.mount_PlexamlR1XKB
.mount_PlexampehEtc
.mount_PlexamTcpCBY
.mount_PlexamZH08fk
Tried running with sudo and it froze in same place. Also tried --no-sandbox
Any suggestions?
