PlexAmp Equalizer won't stay engaged, even though it is enabled
Server Version#: 1.19.1.2645
Player Version#: 3.1.0
In my PlexAmp for Android, I have enabled the equalizer - primarily for use via a bluetooth connection in my car. The problem I have is, the equalizer doesn’t stay “engaged”. It remembers my EQ settings and the switch in app stays in the “enabled” position, but when I leave the car and then come back and reconnect, the audio output isn’t processed with the EQ settings. I have to manually go to the equalizer screen and turn it off and back on again to reapply or re-engage the EQ.
Known issue, will be fixed in the next version.
fixed in next release
Cool, thanks. I look forward to it; it’s driving me nuts! :rofl:
