Plexamp - Expose Style Radio when library Genres set to 'None'
Continuing the discussion from PlexAmp - Style Radio should be enabled when source library Genres is set to None:
Querying whether the fix:
  • (Library) Don’t expose genre radio if user has “none” selected for genre source.
from Plex Media Server - #410 by Ridley should have addressed this.
Steps taken to check:
  • Update Plex Media Server to 1.22.1.4228
  • Update Music library, setting Genres to ‘None’, allowing scan to complete then running Refresh All Metadata
  • Open Plexamp for Android (version 3.4.4): Stations list ‘Genre Radio’ where I would expect ‘Style Radio’
  • Force stop Plexamp for Android
  • Open Plexamp for Windows (version 3.4.4): Stations list ‘Genre Radio’ where I would expect ‘Style Radio’
Changing Genres back to ‘Plex Music’ causes ‘Style Radio’ to replace ‘Genre Radio’ in Plexamp.
The fix was merged into mainline.
I think there might have been a misunderstanding here :thinking: The setting has three values:
  • None: Genres are not read from tags or Plex Music, but you can set them manually.
  • Plex Music: Genres are read from Plex Music cloud data.
  • Embedded Tags: Genres are read from embedded tags.
The radio logic used to be: use genre radio if we’re not reading genre data from the cloud (because it was assumed if you had it in tags you’d prefer them).
The new radio logic is: use genre radio if you’ve selected None (manual genres), otherwise use style radio.
However, that seems backwards from the release note…
Let me flip this around a bit…it would seem like someone would want style radios in all cases EXCEPT when they are reading their precious embedded tags, right?
Agreed.
Edited: I spoke too soon.
This has been driving me crazy for a while, and this thread helps make a bit more sense of the behavior. One clarification based on my testing:
The None value DOES read and update album genre tags from ID3, while also enabling Genre Radio mode in PlexAmp. I tested it by updating local tags and refreshing in None mode and it still updates. It DOES NOT propagate those genres to the artists, however. That didn’t happen until I switched back to Embedded Tags.
I tag all my music locally, and never really want the MusicBrainz/LastFM values. I wish there was a way to have Genre Radio and get the behavior of Embedded Tags. It seems the the two options should be unlinked.
I still can’t figure out how to get Artists Genres in PlexAmp. Even when I switched to None and got Genre Radio, artist pages still show useless Pop/Rock styles.
There will be a fix in an upcoming server release which shows genres radios when the selected option is Embedded Tags (which makes more sense than None).
Looking good after updating to server version 1.23.3.4692. Thank you.
thanks for noticing!
