Plexamp fails to start on Firestick after update
Since Plexamp 4.8.3 startup fails on the Amazon Firestick 4K. 4.8.2 worked fine. 4.8.3 and 4.8.4 seem to install successfully but when run, the Plex logo appears briefly, then the application closes.
Plexamp is not supported on the Firestick (obviously). I’m not sure what would have changed between the two versions, there were very minute changes.
No worries… I’ve gone back to 4.8.2 which works just fine…
If you had a logcat of the failure we might have a clue, there were literally two small changes to 4.8.3 which shouldn’t have had any effect.
