Plexamp for Android Auto Lacks Library Switching – A Critical Usability Gap
Users of Plexamp on Android Auto are not able to are reporting a significant limitation that affects everyday usability — the inability to switch between music libraries directly from the Android Auto interface. The switch indeed blocks the app from working.
I am a user with three libraries can effortlessly switch between them on the standard Plexamp mobile app by selecting the library name. However, when connected to Android Auto, this option completely blocks the app from working. The interface provides no visible control, icon, or menu after the changing. The only workaround is to select the desired library on the phone before driving, which undermines the purpose of Android Auto’s hands-free design and poses a potential safety concern..
The justification often cited in older discussions—“Android Auto does not allow changing libraries”—is technically unconvincing. Plexamp functions as a UI layer communicating with the same server logic available on the mobile app. The restriction is not imposed by Android Auto’s APIs but rather by the current design implementation of Plexamp.
Adding a proper library switcher should be a minimal UI enhancement, feasible within Android Auto’s supported interface components (e.g., simple list or selector). Such functionality would bring Plexamp’s Android Auto experience in line with its mobile counterpart, maintaining consistency and ensuring that users can safely access all their media libraries without needing to handle their phones.
This big fix request deserves prioritisation in future Plexamp releases, given its impact on both user experience and driving safety.
I’m sorry, Android Auto doesn’t provide a UI mechanism to do such a thing that we’re aware of.
and yet, the truth as we understand it. Android Auto isn’t built for rich UI interactions.
Hi Elan,
thank you for this. I am very sorry to hear that. I strongly support Plex indeed. Why dont you try with a different mechanism to switch the library? Plexamp is a great tool and losing traction in playing in a car is a bad deal…. I cannot use plexamp at all: when I load it in my car, the UI is blocked. I cannot use it at all…
Switch the library before entering your car, or consider consolidating to a single library? Most people who have multiple libraries do that for the wrong reasons :sweat_smile:
