Plexamp iOS airplay problems
Loving Plex amp, but I have found a couple of problems, I have in the bedroom 2 HomePods paired as stereo, all all seem to be ok, if I go into the lounge, I have 4 HomePods, 2 stereo pairs and try to play through those and every HomePod is out of sync with each other! …
The other issue is when trying to scroll through a large library, it seems to get stuck and lock up! I hope these are things that can sorted. As I have had to go back to using prism for playing my music at the moment!
Don’t think we have any control over AirPlay and sync, that’s all system-level stuff.
How many items are you trying to scroll through?
ok, just that I am finding Prism app for iOS is working perfectly, but I have to admit it does have an icon on the main ui for airplay, not sure if that makes a difference…?
I have about 600 artist…
Many thanks for your quick response!
