I use plexamp and for the most part, it has been great. there is one small bug that has been driving me nuts for a while. I have a playlist with 37 tracks in it, whenever I enable looping for continuous playback, instead of jumping to the first song, it does the fade in to the first song, then jumps to the 5th song in the playlist. this issue is present on both macos and ios versions (I haven’t tested on anything else) it starts appearing in playlists with more than 21 songs. any help resolving this would be much appreciated.
Are you playing to Sonos or from TIDAL, by any chance?
I am playing media from my plex server.
Playing on the local Plexamp directly, or casting somewhere?
If it’s all local, post Plexamp logs after it messes up.
It is all local.
Plexamp_with_error.log (4.1 MB)
Thanks for the logs, something does look odd, and I can reproduce an issue over here. Will look.
Fixed in the next release.
Awesome, thanks for looking into it.
