Plexamp - Mix Builder, First Artist only
I appreciate the huge fix that came recently where Artist Radios are actually shuffling in unique ways each time now, but I’m still noticing an issue I’ve seen in other threads where building a mix with multiple artists only plays tracks from the first artist’s related songs. No matter how many I add only the first is favored… Is this still a known problem that is being looked into or is this an issue with my plexamp?
Thanks for the help!
I am having the same issue. Mix builder radio only plays songs from artists related to the first one.
What is your degrees of separation set too?
Settings > Radio > Degrees of Separation
one degree will only play related to the “first artist” as you put it,
Just to be clear, you’re playing a Mix Builder radio with multiple artists? Not an artist shuffle?
Play the item, and then post server logs right after.
Ah I think I see the issue, actually. This is my favorite test case :sweat_smile:
Screen Shot 2020-10-15 at 10.34.12 PM
Degrees of separation is set to unlimited so that isn’t the issue.
My test case is Led Zeppelin and Simon and Garfunkel. :grin:
will be fixed in the next release
Yess thank you! Since plexamp 1, using artist radios has changed my music listening experience in such a huge way and this will definitely step it up another notch.
I appreciate the constant support and improvements to plexamp.
