Plexamp (Mobile) and Sonos
Just downloaded the mobile version on android and it looks sweet. I just cant find any way to play it through my Sonos speakers… this makes it nearly completely useless for me :’(
Am I just blind??? are there any immediate plans for this functionality?
There is currently no casting abilities. This is on the roadmap.
Is there going to be Android Auto functionality? Is the roadmap available to view?
No viewable roadmap for us beta testers. It was just talked about and is in the future of Plexamp. I’ve wanted Chromecast integration for a while, but it will be here before we know it. Thanks.
Thanks for your reply, any idea on Android Auto? The regular plex app has terrible AA functionality
AA is also in the works… the casting requires more certificates (at least on the iOS - Apple side) for this to be accomplished, so the idea was to release it and then work with Apple and maybe Google to enable casting.
Brilliant. Thanks for the quite response
How far on the roadmap? I won’t hold my breath, but as #fash202 states, without casting, Plexamp just won’t cut it.
I felt the same after I downloaded the app. Utterly worthless (no offense to the devs) if there’s no way to play it on my Sonos speakers or use it with Android Auto.
also putting in a request for Plexamp + Sonos cast support.
Love the app so far, but majority of my listening is through my home Sonos system and would love to stay in the app to control the experience.
I’ve been enjoying the desktop Plexamp app for mac btw!
With iTunes I was able to clean up names and tags. Now that iTunes is virtually dead I was happy to see Plex upgrade the music server. However this Plexamp release is too rash. The product does offer anything new the main interface already does outside of pretty pictures. Functionality to connect to the choice of output is sort of a major part of a music player. Otherwise I can just enable DNLA and use Windows Media Player. Don’t release half baked concepts. Good idea, but finish it first.
+1 for casting to Sonos, even with massive Wi-Fi overkill AirPlay2 very unreliable for casting to many devices.
+1 for sonos
Are you working with integration to Sonos speaker?
