Plexamp on Android 12 crashes randomly
Server Version#: 1.25.8.5663
Player Version#:4.1.0
Plexamp has been randomly crashing on Android 12 for a while now, when I go back into the app it has saved the progress in the previous track
which logs are needed here for troubleshooting? are there any messages in particular I should be looking for?
I’m not seeing any crashes in our bug reporting system with your username. That leads me to believe it might be the system killing it (aggressive battery saver policy)?
Would need more details, in any event.
thanks for the response Elan, I have checked the battery settings, they were set to Optimised, which is the default, have since changed to Unrestricted, will keep an eye on it.
I will also check playback through the on board speaker as opposed to bluetooth to see if that is any different
