Server Version#:4.160.0
Player Version#:4.12.4
Mac OS 13.7.8
Phone: Honor 600 pro Android 16
Plexamp works normally when my phone is connected to my home Wi-Fi.
When I disconnect Wi-Fi and use Telstra 5G, Plexamp cannot find my Plex server and eventually reports that no servers are available.
However, Plex itself is accessible remotely:
- Plex Remote Access reports Fully accessible outside your network
- Plex Web works over 5G
- I can log into Plex Web on the Honor and see my library
- I can stream music successfully through Plex Web over 5G
- Plexamp works normally over my home Wi-Fi
- Plexamp fails consistently over 5G
I previously used Plexamp remotely over cellular on an iPhone with this same server without problems.
Troubleshooting already performed
I’ve checked the following:
- Remote Access is configured on port 32400
- Remote Access can remain green and report fully accessible
- Server is configured for IPv4
- Secure connections are set to Preferred
- Honor has mobile data access enabled for Plexamp
- Cleared Plexamp app data and logged back in
- Tested with Wi-Fi completely disabled
- Tested with Tailscale disabled
- Tested with Tailscale enabled
- With Tailscale enabled, I can directly access the Plex server from the Honor using the server’s Tailscale IP and port in Chrome
- Plex Web can access and play music remotely without Tailscale
Relevant log errors
The Plexamp logs showed connection failures with:
Error 60
SSL certificate problem: unable to get local issuer certificate
The Plex Media Server logs also show:
error 60 — SSL certificate problem: unable to get local issuer certificate
and:
CERT: incomplete TLS handshake
with:
tlsv1 alert unknown ca
This appears to be occurring when Plex attempts to establish the secure plex.direct connection.
I have also checked the Plex Media Server data/cache locations on the Mac but cannot find a cert-v2.p12 or other obvious Plex certificate file.
At this point I’m wondering whether there is an issue with the Plex server’s plex.direct TLS certificate/certificate chain, particularly because Plex Web works remotely but Plexamp on Android does not.
Could someone from Plex please take a look at the certificate associated with my server or advise how I should regenerate/reset it?
I have not deleted or modified any certificate files.
Thanks!
Plex Media Server.log (7.1 MB)
