Streaming from Studio Mac to AirPlay on stereo reciever
Server Version#: 1.32.5.7349
Player Version#: 1.76.2.3951-15712eae
Please excuse me if I posted this in the wrong board.
I made the leap into audio streaming locally. I bought a receiver that is capable of streaming Spotify, Tidal and others as well as Bluetooth and AirPlay.
If using my iPhone I am able to stream Plexamp to the receiver just fine, it’s really great and I suppose I could learn to live with that.
However, when I try and stream from my Mac desktop I can see the receiver listed in the drop down when I install Plexamp and it even puts the check mark next to it however it still plays on the Mac desktop.
Are their special things I need to do? I have PlexPass.
-matt.
I’m not clear if you are using the desktop app or Plexamp on your Mac. You tagged this plex amp but that is the desktop app version number
As far as I know the iOS version of Plexamp used to be able to specify a per-app AirPlay output but then something changed inside macOS which removed that ability. You should still be able to use the whole-OS AirPlay option with either desktop or iOS version.
Sorry BigWheel. Actually trying both, but gave the desktop app number.
I’ll keep looking, but it’s odd that I can see them and select them on either the desktop or plexamp app, but they won’t stream.
working for me … Plexamp MacOS app (on M1 Mac Mini) … first, select the specific Airplay device for sound output in the Mac system-level Control Center menu … then in the Plexamp app go to Settings > Playback > Audio Output > Audio Device and select Airplay
@tgp-2 Thank you for that, I hadn’t found that. So followed your steps, however, in the Plexamp settings under Audio Output I only have Sample Rate Matching.
SCR-20230824-hjlo
Both on the same network.
Actually, after trying your steps again, except this time using the broadcast button in the upper right corner and making sure that the Integra was selected, POOF, it worked. However, still doesn’t show in the Audio Output selection and if I go into settings it crashes so that’s kind of interesting.
just to confirm, what’s the version number of the (Apple Silicon?) MacOS Plexamp app that you’re using? latest is 4.8.2
if Plexamp app is crashing, probably best to post logs here for the devs to review
Yep, that’s a good idea because it really is crashing a lot… Though I think I’ll start a different post about that, I’m satisfied that this issue is fixed.
